new guy needing help
Postby piezan76 » Sat Feb 27, 2010 9:52 am
hey guys love the site setup with great links and assistance, i just bought a 2005 altima 3.5 se 5 speed, the car is great, decent power reliable and easy on the eyes but the car is horrible on gas it never goes over 14.1 mpg no engine light on and the traction is bad to 1st gear is pretty much useless, anyone have any recommendations on either topics i would greatly apprieciate it
thanks
piezan76
Car: 2005 nissan altima 3.5se
Re: new guy needing help (piezan76)
Postby Mr.Coupe » Sat Feb 27, 2010 2:51 pm
Welcome to the Nico Family Michael. Congrats on the Altima. 14.1 MPG seems rediculous. The previous owner might have not done the maintenance for a while which is why the MPG is crappy. If I were you I would do a complete tune up. I'm talking Oil, Filter, spark plugs, wires, and tranny fluid. I'm not sure if the 05's have a cap and rotor for spark plug wires, but if so replace the cap and rotor as well. Once again welcome to the family. Any questions or help you need just post and you will get a responce to .
Ricky C.
3.5 SE Premium Package, SFR Turbo Kit @ 9 PSI, Eibach Pro-Kit, Stillen Hood Dampers, Stillen Rear Sway Bar, Stillen Strut Bar, AP Racing BBK Front and Rear, Pioneer AVIC-Z3, Stillen Body Kit, SE-R wheels, FK-452 tires.
Stillen Cat-Back Exhaust System for sale:
http://forums.nicoclub.com/zerothread?id=442958
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
Postby wade001 » Sat Feb 27, 2010 3:00 pm
ask your mechanic if he can do a fuel pressure test, if it's higher then spec.(psi) then that could explain it. a tune-up is a good idea regardless.
Racingline STS, WC lathe werks shift knob, Debadged, NISMO Kick Plates, Led's
wade001
Car: 2009 Altima coupe 2.5s mt
Re: new guy needing help (Mr.Coupe)
Postby piezan76 » Sat Feb 27, 2010 5:54 pm
thanks for the quick help but i already did the full tune up exept the back 3 plugs which i kinda got lazy on, do i need to take off the upper intake to do those? because it sure looks that way. ill do a fuel pressure test also thanks again
piezan76
Postby wade001 » Sun Feb 28, 2010 10:44 am
if you have a fuel pressure regulator find the vacume hose on it and dissconnect it. if the psi doesnt change it's a bad regulature. if you didnt already know.
wade001
Postby fiveliterbeater » Mon Mar 01, 2010 3:54 pm
piezan76 wrote:thanks for the quick help but i already did the full tune up exept the back 3 plugs which i kinda got lazy on, do i need to take off the upper intake to do those? because it sure looks that way. ill do a fuel pressure test also thanks again
"kinda got lazy"? c'mon dont treat your car like that! next time just do "half an oil change" while you're at it.
fiveliterbeater
Car: 2006 EVO IX, 2000 Maxima SE
Postby piezan76 » Sat Mar 06, 2010 1:01 pm
thanks for tryin to help guys but i dont even see a fuel pressure reg, does this car even have 1? i used to have a 95 mustang gt and that was way different than this i cant even tell wats what. do i have to remove the upper intake to do the rear plugs or is there some trick
thanks
oh and by the way when i said got lazy i meant i dont know what the hell to do next this nissan is a bunch of electronics
piezan76
Postby wade001 » Sat Mar 06, 2010 9:33 pm
most cars don't have regulators these days but there is always a port somewhere on the fuel rail. another possibility is a bad injector or two. one little test you can do when you take a pressure test is to shut off the car and see if the fp goes down. if it does you have a leak in your fuel system or a leaking injector.
wade001
Return to Altima General Discussions
