dav721074 »
https://forums.nicoclub.com/dav721074-u255671.html
Sun Aug 30, 2015 10:43 pm
BEWARE of ADVANATION! I recently purchased a pair of Halo Fog Lights from them on ebay and they are substandard. The halo ring might as well not be there since they barely light up. The switch that came with them was non-operative and was a cheap stick-on-the-dash type (never even seen junk like that before!). I used my old fog light rocker switch which doesn't allow me to choose the halo ring or fog lights separately so both come on, but as I said, the LED that lights up the halo-ring is weaker than a key-ring flashlight, so no diff anyhow... Also, the internal baffle part of one of the fog lights was 180deg. upside down which caused the light of the passenger side to shine up into the sky instead of down to the ground like a fog light should. I took it apart and rotated the internals 180deg. so it would work properly. Finally, upon inspection of the internal part of the light I had to take apart, the reflective capabilities of the inside of the light are about the same as corrigated tin. Fortunately, the super bright LED's I bought separately for the main fog light part, makes them work OK. They did offer a refund but I had already taped and fused the harness, and secured the lights (that one is on me since I should have checked them closer before installing) so it would have been a bigger hassle than it was worth. I just told them in my last contact with them, that I'd never buy anything from them again and also left negative feedback for selling broken, improperly assembled, and substandard "OEM". I'm going to definitely go to this forum first before getting anything for my pampered 2004 CrewCab Frontier. Everybody seems really helpful and will no doubt have great advice for next time I do on-line-buying.
