IACV fried the computer. It will fry the rebuilt computer if you use it again, you have to buy a new OEM model. Don't forget to perform the idle relearn after you plug in the ECU.So after plugging it back in the RPM wouldn't steady out it would rise and die down repeatedly.
I don't think the new computer even has programming. I have a new IACV in place. Its shiny new still and expensive...... Just gotta replace that connector first to see if that was preventing the IACV from working right?rgk wrote:IACV fried the computer. It will fry the rebuilt computer if you use it again, you have to buy a new OEM model. Don't forget to perform the idle relearn after you plug in the ECU.So after plugging it back in the RPM wouldn't steady out it would rise and die down repeatedly.
