green-psycho wrote:.........Now i just have to ask where is the fuel filter outlet and the coil on this car so I can unplug them......
The fuel filter is the silver cannister on the right side of the pic I posted. The outlet hose is coming out the top.
I suggested disconnecting the outlet hose and cranking the engine but BE CAREFUL not to spray fuel everywhere. It would be safest to put another hose on the fuel filter outlet and run it into a bottle while someone else cranks the engine. This will only verify that the fuel pump is working at some pressure and not tell you the pressure is high enough to pull the beast up a hill. To check fuel pressure you'll need to tee in a pressure gauge.
The plugs/coils are under the long black cover adjacent to the fuel filter. It's easiest to remove the passenger side cover and then the front (#2) coil. Remove the coil and plug, reassemble outside the cylinder, crank the engine and see if it sparks to the engine block. If you have any amount of fuel pressure and spark the engine should at least start. There's many other things to check but this is a good start.
Have you held the pedal to the floor and turned over the engine for 30+ seconds to make sure it's not flooded? A compression check may give you low numbers if the engine has been flooded and the cylinder walls are washed. Any strange noises when you do this?
goody94q45 wrote:
