nastys13 »
https://forums.nicoclub.com/nastys13-u58966.html
Wed Oct 14, 2009 1:31 pm
I’ve decided to pull the engine out of my 93 N/A (155K)because it seems that some of the components are starting to fail. The block has good compression, but things like the water pump and miscellaneous gaskets are starting to go south. My alternator is covered in so much oil it’s ridiculous. I’ve done engine swaps back in my Honda days, and I’ve done a 240 swap as well. So I would say that I’m fairly knowledgeable when it comes to that kind of stuff. I got most of the wiring harness removed, and all the other stuff that ties the engine down.
However I noticed a wiring harness that comes from the back of the tranny, and snakes behind my exhaust manifold and continues to my alternator and stops somewhere near the passenger headlight. Any tips on removing this would be great. It looks to me like the only way I can disconnect the alternator is if I un-bolt it and carefully support it up while getting access to all the wiring connections.
Also how do I free the engine block from the motor mounts. I think I can access the driver side mount just fine, but the passenger side has the power steering pump in its way, if I was attempting to get to it from the front of the car.
Finally where is the best place to fasten the engine when it comes time to hoist it out.
Any help with these question would greatly help me thanks.
