holymolyNc wrote:Oh ok I did some looking around on that particular website didn't find the strut but did find the mounts,sleeves,and etc which am sure need replacing as well . So where do you actually "refill" and check the fluid from the struts?
Not sure what you mean by checking the fluid in the struts. Each side has a sealed strut "cartridge" that gets installed inside the strut housing. You have to completely disassemble both front struts by removing the entire assembly from the car, undo the strut mount, remove the springs and then unscrew the large nut at the top of the assembly to remove the inner strut cartridge. If you are located near Chicago, I would be willing to replace both front struts for a reasonable price since I bought a wall mounted strut spring compressor specifically to do this job on my 98 Q.
Unless you have Arnold Schwarzennegar strength or a really powerfully impact gun, you will not be able to compress the springs far enough using those rental tools from Autozone. Trust me, I tried with no success. Send me a PM or email at
[email protected] if you are in the area. I just did my right strut mount two weekends ago after I blew it out hitting a major pothole last winter.
Ted
