need some pointers.
need some pointers.
Postby madsx » Mon May 14, 2012 7:24 pm
well my redtop started smoking its not a constent smoke.. it smoke every other time like when im on a stop light or when im driving..
so i took it out today im thinking its my valve seals. im going to put new seals for sure.
what else should i check for in my motor that. whats the best way to check if my block have wear on the sleeve?
any help would be appreciated..
madsx
Car: 240sx
Re: need some pointers.
Postby compactfean » Tue May 15, 2012 10:13 pm
If your car smokes alot when it initially started id say valve seals, by your symptoms though id probably go with turbo seals. Id pull the turbo and check the front and the back for excess oil in the housings and on the turbine and compressor.
compactfean
Car: 89 240sx s13 sr gt3071r 23psi
B14 sentra ser sr20de-t 7psi
daily
Postby madsx » Tue May 15, 2012 11:26 pm
the engine is out already... thinking that it was my valve seal but know i think is pistons rings..
from the bit of knowledge i have a piston shouldn't have any type of play, well i checked my piston for play and they do have play, can it be that my pistons rings are gone? thats why it smoke.
madsx
Car: 240sx
Postby compactfean » Sat May 19, 2012 7:16 am
Well yes, but it could be a number of things.... Rings and valve guide/seals are most common. Also the turbo can cause smoke.
compactfean
daily
Postby madsx » Sat May 19, 2012 1:57 pm
well i took it apart today, i took a piston out, rod bearings are std also pistons are std.. what worries me is that the pistons have side to side play. if they are move you can hear them hit the piston bore wall..
motor has not spun a bearing should i order bearing in std in acl or clivite or any other brand besides stock nissans. or should i send my crank to get work on?
piston measurements were 85.80
block bore was 85.90
stock spec
.. my next step is to measure piston ring wear and check for taper or any other wear in the cylinder walls.
i have the fsm for s14 sr.. thats what im following for reference.
my plan is to stay with stock bottom end. but if necessary ill go .5 over and eagle rods and acl or clevite bearing.
madsx
Car: 240sx
Postby compactfean » Mon May 21, 2012 9:22 am
How did you measure the bore and piston size? I don't remember the min specs but if you are .1 inch than that is no good. Did you use snap gauges and a micrometer? Your measurements don't sound right.
compactfean
daily
Postby Seishuku » Mon May 21, 2012 5:01 pm
That's .1 mm... I hope it's not nearly an 1/8" out! lol
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T@11PSI, Megasquirt 1 029y4
Postby compactfean » Mon May 21, 2012 9:30 pm
Haha! I didn't even think about that, I just automatically starting thinking in thousandths of an inch difference as if I were measuring between the piston and wall. Yeah 1/10 of an inch would be scary.
compactfean
daily
Return to SR20DET Forum (rear-drive)
