Hey guys, my names Alex, I've been a Nissan owner for 6 years and recently a q45 owner as of October.
Everything was going great until I had a tail light bulb melt and ground out to the socket wall.
Car: 1994 Infiniti Q45 base, 124k miles
So as the story goes, driving along, have cruise activated, cruise shuts off, cruise lamp on instrument panel flashes ~10 times, and does not illuminate again. Then I lose brake lights, and next instrument panel lights, radio lights, hvac lights.
After some inspection I find that the brake light bulb has shorted out, replaced the bulb, and the fuses for the tail lamps and stop lamps(can't remember exact verbage). In the process I checked my brake switches, and my tail lamp sensor in the trunk. The switches work, and the tail lamp sensor in the trunk doesn't appear to be damaged(solder joints look okay).
At this point, I have stop lamps(with headlights on or off), but no running lights, no instrument panel lights(including radio/hvac), and when I turn my head lights on, both the low beams and high beams kick on. I replaced the head light switch and it does the exact same thing so I'm guessing it's not the headlight switch.
I'm really kind of lost, hoping someone has encountered this problem and has a fix or can at least point me in the right direction.
Thank you in Advance,
Alex
