loystock »
https://forums.nicoclub.com/loystock-u10145.html
Sun Feb 14, 2010 10:05 am
Have you checked the fuse for the wiper motor? It should be Fuse #39, 20A of IPDM in the engine bay.
Transmission flush is recommended every 30K miles. Better do a pan drop, clean pan and magnets, replace ATF filter, install new gasket and crush washer then do a flush. At the end of the flush, add a bottle of LubeGard Red (not black) ATF Protectant.
Instead of a flush at the shop, you can do multiple drain and refill (run engine for @ 100 secs while shifting gears, then drain). Make sure the engine is warm and the ATF level is correct before doing any drain/refill. Always add the exact amount of ATF drained. The 05 Maxima with Automatic transmission requires Nissan Matic-K (7-3/4 quarts capacity).
