1. Lower harness by alternator and starter, what is necessary to connect? i seen couple plugs that are not connected. (i already connected power wire) So alternator wire and starter wire?
2. Relays for harness, i marked all wire relays. I should have 2 relays one for fuel and other for ecu power?
Any great suggestion on wiring relays, i currently have switches that operate everything. One is for ignition power and other for fuel pump (this is from my previous set up, build by previous owner)
Basically just trying to wire up ecu and fuel pump with aftermarket relays, if anyone has a DIY i will greatly appreciate.
Thanks guys
