rioredstang wrote:Did you get the codes? What are they?
0607
Thanks for the reply. I used the procedure where you disconnect the diag connector near the starter solenoid and jumper pins 3 to 6 for two seconds. The check engine light blinked six long seven short,0607 which in the table says Cylinder 2 misfire detected.
Which doesnt make sense at all. Could it be that I didn't drive farenough to generate any EGR related codes ?
I did the above procedure with the ignition switch onand the engine NOT running.
If multiple codes are stored in the computer, will this procedure read out ALL the codes ? Or do I need to do something else to get more codes. Guess I could drive down to Advance Auto but that would be too easy.
Any ideas on this ?
Modified by mskipatrol at 3:29 PM 2/26/2010
Modified by mskipatrol at 3:34 PM 2/26/2010
