Hello everyone.
I have a 2012 rogue SV with a factory backup camera/siriusXM radio with bluetooth which i am replacing with the Clarion NX602.
I plugged in all the wires, but I am stumped on the camera and steering wheel interface wires.
I bought a pac audio SWI-RC and they show these instructions:
http://www.pac-audio.com/SWI/SWIAppGuid ... o%20+%20BT
I see there these pinouts for 2 connectors, the Nissan08 (the regular wiring harness which I have the adapter for) and the Nissan32bt (what they call a "b55" connector).
http://www.pac-audio.com/SWI/images/nis ... an32bt.jpg
I also have been searching extensively online about this, found that I can reuse the factory-installed backup camera since it is a regular RCA, and found an "M89" connector (which i think is for rogues with a nav system factory installed) and is different than the B55 I have. The pinouts for M89 show that the backup camera's 4 wires (2 power and 2 video signal) are pins in the M89 connector.
I found that here:
http://www.kenwoodforums.com/viewtopic. ... d&start=10
and directly here:
http://www.kenwoodforums.com/download/file.php?id=1052
However, I don't know which pins they are in my connectors (either the B55 or another ones that I don't know what it does).
So being that pictures speak SO much louder than words, I took and edited the following pictures so you can see my factory radio and the wires I have:
here is the imageshack link for all of them
http://imageshack.us/g/526/img00434201208081929.jpg/
and here are the direct links individually:
http://imageshack.us/f/100/img00435201208082143.jpg/
http://imageshack.us/f/28/img00430201208081928.jpg/
http://imageshack.us/f/846/img00431201208081928.jpg/
http://imageshack.us/f/528/img00432201208081928.jpg/
http://imageshack.us/f/526/img00434201208081929.jpg/
http://imageshack.us/f/850/img00433201208081928.jpg/
So in short, I am asking if anyone knows where are the 4 camera wires?
Is there is a reverse positive wire in the harness or anywhere else for me to plug into my Clarion so it knows when the rogue is in reverse?
And what is that blue cable for?
I read in the link I gave before (with the m89 connector) that the backup camera requires 6volts. Is this true? what would happen if I just wire the regular 12 volt power that the clarion gps uses? (I used 12 volts for the aftermarket backup camera I used for my altima)
Those are my camera questions.
For the steering wheel interface, I think I got the wires worked out in the harness (im just trying to destroy a spare harness to harvest spare pins from it as I need another 3 that my harness that I'm using doesn't have).
The only problem is I am required to disconnect the bluetooth module which is in the trunk on the right side wall panel.
Does anyone know how to remove that panel? (it is hard plastic and I'm only used to removing soft lining from my altima trunk ;-) )
On a last side note, is there any way to rig the satellite antenna to use with other sirius radios (if I get the sv2000 would it be the same shape or riggable?
I only have like 2 days to finish this before I go back to school so if anyone can help me I would REALLY appreciate it.
Thank you for all your help!
