SunLitSandMax00SE »
https://forums.nicoclub.com/sunlitsandmax00se-u49231.html
Thu Oct 11, 2007 7:45 pm
So I got an h4 HID kit. The kit came with the ballasts, connectors, bulbs and the two wire casing things. As you can see in the pictures, I am having a hard time figuring out why the when I plug in the red and black prongs into the stock power plug connector and then the other black wire coming from the black wire with the prong (I'm guessing is the ground wire) is grounded......I don't know why they won't turn on.
I'm guessing none of that made sense
As you can see in the pictures, the kit only came with 2 prongs (red and black) to fit in the 3 pronged stock power plug housing.....how does that work?
The smaller black wire coming off the black wire with the prong.....I grounded that on the bolt shown in the picture (between the screw and bolt)......
To make matters worse, now my headlights don't work with just the stock lights in...... I need some help
*sorry for the horrible quality pictures, I can't my digi cam
