Need Help doing an Install? Check our DIY SECTION!
Postby LongBeachCoupe » Sun Jun 22, 2008 9:06 am
http://www.nicoclub.com/subpag...ltima
I have a feeling a lot of you didnt know that there is a consolidated list of DIY threads, and that if you do a write-up on a DIY (from mild to wild) you can get a custom title added under your NICO tag.
LBC Overlays are HERE! INSTOCK & $32 DELIVERED!
20" ADR Propulsions-SurmanM Custom Dash Cluster -Racingline Front Strut Tower Bar-SBD Grounding Kit-Stillen Lightweight Pulley-Stillen RSB-Xentec Heads n Fogs- Chrome Signals -Fiberglass Eyelids - Eibach Pro-Kit- Fujita WAI - Nismo CatBack - 15/5% tint - Red LED Interior
LongBeachCoupe
Car: 08 Altima Coupe
Re: Need Help doing an Install? Check our DIY SECTION! (LongBeachCoupe)
Postby troy15 » Mon Jun 23, 2008 1:23 pm
yo mad funny...i was driving home from longbeach like last friday night
i seen you on longbeach road i hi-beamed u. The eyelids look sick plus the rims wit the crome lip nicely done. Where did u order ur fiberglass eyelids..iwent to speedworld in baldwin n they cant find em.
BLACK ON BLACK A/C 3.5L,V6, 20%TINTS, SMOKED FOGS WITH YELLOW BULBS
troy15
Car: 2008 Nissan Altima Coupe'
Re: Need Help doing an Install? Check our DIY SECTION! (troy15)
Postby LongBeachCoupe » Mon Jun 23, 2008 1:46 pm
Speedworld? why would they have it there? INTERNET FTMFW!
Sorry i didnt see you, email me and we will meet up.
Do a search for "eyelid" (member training) and you will find the links...
LongBeachCoupe
Postby troy15 » Mon Jun 23, 2008 1:49 pm
thanx will do bro
troy15
Postby Marisha » Thu Dec 04, 2008 6:46 am
hey Brian, you think you could add the one I made for the K&N install there (and wherever else it's supposed to be)?
oops...linky... http://forums.altimas.org/zero...guide
NICOfest 2009
Marisha
Car: 2008 Altima Coupe 2.5S
Postby marlin29311 » Fri Dec 05, 2008 11:07 am
Lol, this may sound kinda odd and I know the vast majority of us know how to do it already, but there is no HOW-TO on how to change your oil! Could be something useful for a new car owner looking to get their hands greasy!
PS - i just realized that the CEL/SES writeup was mine! No custom title? Boooo...lol.
Sorry, I'm really bored at work...
marlin29311
Car: 2008 Nissan Altima Coupe 3.5 CVT w/ Prem, Tech, VDC
Re: Need Help doing an Install? Check our DIY SECTION! (marlin29311)
Postby telcoman » Mon May 18, 2009 11:01 am
marlin29311 wrote:Lol, this may sound kinda odd and I know the vast majority of us know how to do it already, but there is no HOW-TO on how to change your oil! Could be something useful for a new car owner looking to get their hands greasy!
I'm not sure why there is no write up on changing oil.
http://forums.g35club.org/zerothread?id=289523
Although the link describes the oil change on a G35 it pretty much applies to any vehicle.
Look in the owners manual for the location of the jack points underneath the vehicle. Our 2009 Altima is only a couple of weeks old so no oil changes have been done yet. The wife drives very few miles so it will probably only get done twice a year whereas I have changed the oil 27 times on my G35 as I put on 2k miles a month
Anyway acquire the following
3-4 ton hydraulic jack
ramps,
jack stands
a plastic container to hold the waste oil,
plastic funnels
a creeper to roll under the vehicle
A set of sockets, 3/8 & 1/2' drive
an oil filter cap wrench
oil filter from dealer(keep receipts)
some rags and paper towels
I purchase 5w-30 oil where ever it is on sale
I use an old plastic shower curtain under the vehicle which makes it easy to wipe up any spills and I have a small bag of kitty litter just in case.
The dealer wants $40 at Infiniti so $40 X 27 oil changes has saved me $1080.00 thus far. Additional savings adds up from rotating tires every other oil change and replacing air and cabin filters.
Jack up vehicle & place ramp under each front wheel
Remove the fiberboard shroud from underneath the vehicle
The oil drain plug on the Infiniti takes a 14mm 1/2 drive socket. It may be the same on an Altima but with a set of sockets it doesn't matter. Just use the correct socket to loosen the drain plug with the socket wrench and let the oil drain out into a funnel into you plastic container. Open the oil cap on top of the engine before removing the drain plug.
Remove old oil filter using cap wrench
dip finger into a full qt of new oil to lubricate the rubber seal on the new oil filter. Wipe around the metal once the old oil filter has been removed to be sure everything is clean prior to screwing on the new oil filter. Tighten as hard as you can by hand and then use the cap wrench to tighten another 1/8 of a turn.
Replace drain plug and washer by hand and then tighten with the socket wrench just enough so the plug cannot loosen by itself.
Add the new oil as specified in the owners manual.
Prior to replacing the fiberboard shroud, start the vehicle, get out, look underneath to be sure there are no leaks around the oil filter or the drain plug.
Shut off engine, replace fiberboard shroud, remove vehicle from ramps and check oil on dip stick. It should show at the F mark
You are done and go grab a beer
Telcoman
2006 G35 6 Speed Manual Premium Package A Sirius Radio 123,243 miles. No mods required, I love her the way she came. Mod money goes to 401K. Regular 87 Octane, all the time. Last fillup 9/2/10 25.05 MPG @ $2.39 gal with regular 87 octane.
telcoman
Car: 2006 Infiniti G35 Sedan 6 MT. Mods unnecessary, Money goes to 401K plan. 2009 Altima 2.5S
Re: Need Help doing an Install? Check our DIY SECTION! (telcoman)
Postby marlin29311 » Tue May 19, 2009 2:21 am
Telcoman
Old news Telco...
http://www.nicoclub.com/articles.php?id=408365
marlin29311
Postby telcoman » Tue May 19, 2009 9:22 am
marlin29311 wrote:
Old news Telco...
It must have been a senior moment?
I saw it today but did not see it previously on the Altima forum
I'm also new on the Altima forum as we just got the 09 Altima 2.5S a few weeks ago
Telcoman
telcoman
Postby ja105ny » Thu May 28, 2009 2:25 pm
for custom brake light:
http://forums.altimas.org/zero...27296
ja105ny
Re: Need Help doing an Install? Check our DIY SECTION! (ja105ny)
Postby Ricko » Sat Nov 28, 2009 11:00 pm
phucking put this up already.
http://forums.altimas.org/zero...ttery
too many people inquire about this.
Ricko
Postby Ranga14 » Mon Nov 30, 2009 1:26 pm
The link for "How-To: Changing the In-Cabin Filter" goes to a broken page of some sort.
Ranga14
Car: 08 Altima Coupe 3.5
Return to Altima General Discussions
