LGmobile wrote:For the 08 stock navi bose to accept the new unit, the following parts need to be replaced/removed
1. Master av control unit (can come from anything 2010+ 370z, ex35, g37, fx, etc)
2. LED Display screen (can come from anything 2010+ 370z, ex35, g37, fx, etc)
3. Main buttons (heat/volume) if you dont like the cf card hole. (ex35 specific, camera button, these are paired with the top buttons under the screen so keep them together or the buttons under the screen will not perform the printed function)
4. new--> usb port for center console ($50)
5. new--> usb wire from head unit to center console has to be custom made
6. new--> shielded cable from av unit to new LED screen for digital video has to be custom made
7. remove ipod box behind screen (no longer needed)
Things that remain the same (plugs)
1. am/fm antenna + plug
2. sat antenna + plug
3. xm antenna + plug
4. Around View monitor (can be upgraded for more features but it does work as is)
- NOTE: The AV system will show an error code in the navi diagnostic mode under "AV Comm", it is looking for the 2010 AV module and your system is 2008. All features still work as a 2008 including sonar.
All the plugs and sockets are the same but the pins need to be rearranged, I made a whole document on how they line up in excel I could post up. I just dont like posting too much stuff since with my previous car on a forum people tried things, messed up their cars badly and were mad at me. But for a skilled individual with time on their hands, its a fun project.
Wow. It doesn't sound as 'straight forward' as I thought. I thought it would be more of a 'parts swap' type of deal; for me, the requirement of rearranging the pins is probably the step I wouldn't want to go into, as it requires a good amount of time, organization, and tracking.
I know that it'll be highly unlikely that I'll try something like this. I wouldn't consider myself much of a "skilled individual" and I know I won't have the time, so I won't be able to have fun with this project. Because of this, I promise you that if you post up an instructional thread, I won't get mad at you.
However, if nobody else shows interest, I wouldn't want you wasting your time writing everything up.
Nonetheless, I do admire what you've done and the effort you put into it. Thanks for sharing.
