Nav Hack in NJ
Newarker22
Car: 2006 Infiniti M35X, Technology Package, Crimson Roulette w/ graphite/rosewood
Just had the Nav Hack done for my 2006 M35x. Very happy with the work, and it works great. Switch was installed under the arm rest inside the center console.
The work was done by Auto Image 16 Frelinghuysen Avenue, Somerville Circle, Raritan, New Jersey 08869.
+1 (908) 218-9757
I was charged for 2 hours work.
I am now having them install an Escort PASSPORT 9500ci
cruzad3r
Car: 2006 Infiniti M35x fully loaded
so how much for 2 hours of work?
Newarker22
I believe it was $85/hr
cruzad3r
cool
JasonR
Car: 06 M45 Sport
Newarker22 wrote:Just had the Nav Hack done for my 2006 M35x. Very happy with the work, and it works great. Switch was installed under the arm rest inside the center console.
+1 (908) 218-9757
Newarker22 Im also located in NJ how did the work come out? and problems at all after install was done Im looking to get this done.....thanks in advance!
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
Would have to agree with Eric...
I am certainly no auto electronics whiz-I did it in 3 hours (I went really slow cuz' I didn't want to mess anything up) and used crimp connectors and not soldering--just in case I need to put things back to stock. Taking out all the screws and removing the glovebox was the hardest part. But if you do this hack, you can also change the in cabin air filter as well, because it's only another panel or two to remove, once the glovebox is taken out. I wasn't able to put the switch in the original place the guide suggested-I didn't have enough room, so I used the middle console area as well.
If you search Nav hack, you can find a good step-by-step guide to doing this with pictures and diagrams. I didn't use Cat 5 wiring like the guide suggest, I just made sure my wires were labeled correctly with colored tape to keep it all straight and organized.
JasonR
Car: 06 M45 Sport
I did find the write up for the nav hack with pics and step by step instructions I think I might give this a go and take my time, like you guys mentioned it seems straight forward appreciate the help guys!
riggz
Car: 2007 M45S
Please post up pics of the 9500ci install! I'm thinking about going this route.
06M4.5
Car: 2006 M45
I also did this mod myself.
JasonR
Car: 06 M45 Sport
06M4.5 are you also in NJ?? Im just wondering if I have any question or problems If I can go to someone locally who has had hands on experience with this before
06M4.5
Car: 2006 M45
I'm in Jersey City, 8 blocks away from the Holland Tunnel. exit 14c Turnpike
job is not hard, just takes a little time. all you have to do is get to the back of the gps/dvd player and add 1 switch.
I placed the switch next to the player, I'll try to have a pic for you tomorrow.
need help let me know.
Freddie
JasonR
Car: 06 M45 Sport
Thanks Freddie appreciate it!
06M4.5
Car: 2006 M45
I got this switch from Radio Shack
hope this helps
JasonR
Car: 06 M45 Sport
Wow thats clean looks OEM as if It came from the factory like that lol
mgokool
Car: 2006 M35x
used the same switch with my setup last year! Very clean for this mod! Put mine in the arm-rest console...
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
06M4.5 wrote:I'm in Jersey City, 8 blocks away from the Holland Tunnel. exit 14c Turnpike
Freddie
how much would you charge to do the hack for someone? someone mentioned the GPS signal lagging at times b/c of this mod..are you experiencing that at all?
06M4.5
Car: 2006 M45
I'm not an installer, I only work on my cars. I do big & small jobs, what -ever I can do. But I don't like to play with other people's cars.
but I'm willing to give you a hand (free help) on doing the DVD by-pass if your willing to come to my house.
all you need is the switch and the 2 small connectors that go to the switch, I have the rest. tools & wires.
I went to a stereo shop and was told $85 and they didn't know what had to be done. you can save that money by doing it yourself. use that money for another mod.
DoN_BLaZe34
2006 FX45 - Traded
Cool, would give me an excuse to meet another M45 owner in Jersey. Any issues with you NAV lagging?
06M4.5
Car: 2006 M45
I haven't used the nav or dvd player much but I haven't seen any issues yet.
don't forget your only adding 1 NEG wire just to see the screen. this has nothing to do with the performance of the GPS. The weahter, clouds, rain, buildings, over passes and location all will effect the performane of the GPS.
now the other wire is being switched off in order to play the movie while driving. as long as this wire is connected your GPS work like normal. when you hit the switch and now the wire is broken your on the movie mode which will effect your GPS until you hit the switch again. then you have to let the GPS catch up by stopping at a red light or just pulling over to the side for about 5-10 seconds.
MasterFoo
Car: 2007 M35X Black with Bourbon interior
^^^ 06M4.5 What tools did you require for the mod? Did it essentially void your warranty? thanks.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Looking to do the Nav Hack on my '08 M45s anyone had this done yet? I'm in Houston, Tx.
I've looked on this forum many times before and have found many hack jobs on '06-'07.... :confused:
The Bodyguard
The instructions for the 2008 M35/M45 is slightly different. Here is a link to those instructions.
Good luck! :yesnod
Thanks for the link on the '08 nav hack. I will see if I can print the instructions and do it myself or with help from a tech who helped do a friends '07 g35. I'll let you know how it goes.. :bigthumb:
The Bodyguard
infiniti_lineup wrote:
The Bodyguard wrote:Thanks for the link on the '08 nav hack. I will see if I can print the instructions and do it myself or with help from a tech who helped do a friends '07 g35. I'll let you know how it goes.. :bigthumb:
Anytime! :yesnod
Be sure to check back if need any help or get stuck along any point. Also, try to be careful when pulling up the wood trim along the shifter and ashtray, the clips on front side of it can be easily broken if it's pull up too hard. Again, good luck!
Not sure I could do it..the instructions on here are very clear and looks doable by an amateur tech like me but I got a quote today by a local shop that did my friends g35 sedan and price was $45!! needles to say I jumped on it and got it scheduled for monday nov. 30! will let everyone know how it goes and post the number and location of the shop if all is good!! ;)
The Bodyguard
06M4.5 wrote:I got this switch from Radio Shack
hope this helps
I got my Nav Hack done tuesday here in Houston...Total cost was $80 (he had quoted me $45/hr) and found this same switch at the local AutoZone!! I had the switch installed in my center console next to dvd player...smooth! SAL'S AUTO SPORT! 290 NW Fwy and Fairbanks Rd (Danny) Next to Top Dollar Pawn!
m35_driver
Car: 2006 M35
2hrs 45 min.
Took time with the solder work. Opted for the switch next to the Nav DVD in glove box. Great instructions here, thanks for posting!
On to the LED fog light conversion...
hoang5659
Car: 2006 M45 Sport
hi i'm new to this forum...
can someone please post the write-up for the nav hack? i have a 2006 M45 and i dont know how to find the write up. thanks.
hoang
cruzad3r
hoang where you at? also do a search and type in nav hack, you'll get it. if not here, do it through google.
kys2000
Car: 2006 EVO IX
Just did this hack myself on my 08' m35x. I also went ahead and added aux composite inputs tapped in the center console aux inputs for when I add my DvD player. Overall its pretty easy once you follow instructions, it took me a couple of hours each days and three days of working on it but, I did all soldering I could outside of the car, I also shrink wrapped and electrical tapped everything down as well as used corrugated wire covering for added protection and discreteness. Over all, I'm happy with the work and my Navi tracks location fine. I'll have to check it over a longer distance to see if it lags any, just tested for about 3 miles tonight when I finished.
audtatious
Here's a repost of all the instructions:
(Remember you can click to expand the images)
Thanks to the guys at CARfag.org for these instructions.
