Welcome to NICO.
Make sure you loosen the nut on the idler pulley first then loosen alternator belt tension thru the idler pulley adjuster (top, long nut). Access to the nut is tight but once loose, the others will be easy to do. Here's a YouTube video of alternator belt replacement on a Maxima (similar to I3), courtesy of "boredmder." This will give you an idea on how to loosen the alternator belt so then you can take out the alternator.
http://www.youtube.com/watch?v=bJzpTHIky18
