Shocks, springs, sway bars, coliovers, bushings, brakes, rims, tires - You name it, this is the spot to discuss Altima suspension modifications!
N00b with wheels, couple of questions
Postby bl4ckph4nt0m » Mon Nov 09, 2009 12:21 pm
Im a noob with wheels, couple questions here
1) i was reading on the forums, that you can put 350z (touring), maxima and infiniti g37 wheel on a/c. i was wondering, if anything extra i need to purchase to make then fit or it is just bolt on and drive off.. cause on 350z the front wheel is diff then the rear wheel?
2) putting on g37, maxima or 350z wheels (touring), , will that effect my speedometer (19" wheels)?
3) what does staggered mean ?
4) would this fit by just bolting them on? http://cgi.ebay.com/ebaymotors...33ed3
4) is it recommended to drop the car first and then decide on wheels?
5) would i need alignment done, if i only get new wheels installed?
6) would i need alignment done, if i only get springs installed?
sorry if these questions are noobish .. i did some reading, but wasnt clear on somethings .. thanks
Modified by bl4ckph4nt0m at 2:52 PM 11/9/2009
bl4ckph4nt0m
Car: 2009 Altima Coupe 2.5S
Re: N00b with wheels, couple of questions (bl4ckph4nt0m)
Postby bunda4th » Mon Nov 09, 2009 2:59 pm
1. You can fit G and Z wheels on but make sure to buy 4 front wheels. To have the same offset and width. Maxima wheel should fit find.
2.It will effect your speedometer a bit, just make sure you get the right tires to go with the 19s so that it wont be a drastic change.
3. Stagger means your rear wheel is wider than the front. basically 19x8 +35 front and 19x9 +30 would consider stagger. (offset does not really matter)
4. The link is for the rear wheels of a G so basically you would need the front set and you will be going stagger.
5. (you have two 4s....) I would lower the car first and then get the wheels because you will be sitting much higher with the 19s and wheel gap = ugly to me. (my opinion) But I say go with a drop first than some wheels.
6. You will not need to get an alignment done if you are just putting wheels on.
7. If you lower your car, then yes you will want an alignment done.
Hope that answer all your questions but feel free to ask any other questions.
bunda4th
Car: 2008 Nissan Altima Coupe 2.5S 6MT
Re: N00b with wheels, couple of questions (bunda4th)
Postby bl4ckph4nt0m » Tue Nov 10, 2009 4:13 am
THANKS ALOT !
couple question to clear up somethings ...
1) for maxima all 4 wheels are the same size correct? i dont have to buy the 4 front ones, right?
2) whats the best place to look for 18" Z touring wheels?
3) and if i get either 17s, 18s, or 19s ... what tire size do i need, so that it doesnt effect my speedometer to much?
4) for Z wheels its okay to have a normal set .. 2 front 2 rear .. and have them staggered ... or no .. i have to have 4 front wheels
thanks again for all your help
bl4ckph4nt0m
Postby mikegtr06 » Tue Nov 10, 2009 7:22 am
you dont need to get all fronts with the z wheels.. i have mine the,m and mine are staggered with 225/45/18 on the front and 245/45/18 out back... they all sit perfect flush..
mikegtr06
Car: 2008 altima coupe
FN-QR
Postby jaxcoupe » Tue Nov 10, 2009 7:35 am
I've got 350z track wheels with 2 fronts and 2 rears, with the same size tires as mikegtr said. Fits fine, don't need anything extra
jaxcoupe
Car: 2008 Altima Coupe 2.5S CVT
Re: FN-QR (jaxcoupe)
Postby bl4ckph4nt0m » Tue Nov 10, 2009 9:08 am
thanks guys ...
hey mike and hannah can get some pics of your guys wheels ... i know mike you have it in your signature .. but .. can i get a bigger pic ..
thanks again
bl4ckph4nt0m
Re: FN-QR (bl4ckph4nt0m)
Postby iammai » Tue Nov 10, 2009 12:07 pm
Look at the rim thread at the top of the page. Pics of 3 different 350z wheels and pics of g37 wheels as well as M45 wheels.
iammai
Car: Altima coupe
Return to Altima Suspension, Brakes, Rims and Tires
