D-unit would you be able to share the 300zx flow data your using with your abaco? I have a power fc now and it would be much easier to just use a 300zx maf table.D-UNIT wrote:Hells yes! I'll never use any other!!!It has been FLAWLESS well except the time my turbo slowly began to come loose and the MAF started sucking in the hot and fuel rich exhuast smoke. It coated the inside with an uncleanable soot that blackened the sensitive air sensors. I sent in for service ( very great service btw) it was toast so they hooked me up by coreing my bunk sensor and sending a brand new one for $192. It was my fault so I was thankful. Normal repair are much cheaper.
I have the 97mm one too. no problems even N/A it had no trouble reading the minimum amount of air. I could even dip down to 400rpm in 5th give full throttle with no shaking what so ever! Just pulling haha. The best thing is the ten settings you can program in and change in-car. you can have a 100 oct setting a high boost setting and daily even a lean "emissions" setting without hooking up to a computer.
I have the JWT stage 4 turbo program that uses the ford corba MAF. Its for V8s so I'm using that specific setting. Just download their software (free) and search for your app. If not for $50 you send in your MAF , they flow it and make a custom map for you.
