Re: My Vert 5speed swap (biggie)
Postby krash » Mon Jan 25, 2010 8:41 am
sweet, harbor freight is awesome. keeping the damper system eh?
XenonSE-R wrote: And that is the beauty of automotive enthusiasm - to make more out of less for your own purposes. Some can afford more, some can't.
krash
Re: My Vert 5speed swap (krash)
Postby biggie » Mon Jan 25, 2010 9:20 am
krash wrote:sweet, harbor freight is awesome. keeping the damper system eh?
I was going to keep it since the hardline was all in one piece and wouldn't need to be bled. Now since I have to remove it to route the hardline, I'll just bypass the dampner. Just have to wait to get a hold of a flare wrench to break them loose.
'93 S13 Coupe SE - KA-T, 10psi, 282hp/287tq
'93 S13 Vert LE - Weekend cruiser, 5spd
'03 G35C 5AT - DD
biggie
Car: (2)93s SE coupe/LE vert / '03 G35C 5AT
Postby 94vert » Mon Jan 25, 2010 11:22 pm
looks good so far i still have to swap mine.
94vert
Car: 1995 240 vert
Postby biggie » Wed Jan 27, 2010 4:58 am
Ice/Snow for this weekend will probably stop a friend from bring tools/helping. Probably won't get done, crap.
I'll try to get pics tonight or tomorrow of the pedals progress.
MDM-100 should be here today, maybe see how I'm going to route it over to the pocket below the radio or where else to put it.
biggie
Postby biggie » Wed Jan 27, 2010 5:58 am
IIRC isn't there a shift lock connect at the ignition you can disconnect to stop it from locking?
biggie
Postby biggie » Sat Jan 30, 2010 8:15 am
Damnit. Pilot Bushing puller from AutoZone is too big to even fit inside the bushing. Have to go get the one from Advance. Of course who knows when I'll be able to leave the house, only thing that's driven in front of my house is 4-wheeler.
So much productivity this weekend. Did clean up the garage a little and swapped out the old boot with the new ebay one, good fitment, definitely worth the $11 or so it seems.
Old:
Old vs new:
biggie
Re: (biggie)
Postby Harman850T5 » Sat Jan 30, 2010 2:30 pm
If you can get a hold of a Matco dealer get the pilot bearing remover. Part#: CP55600
It saved me a lot of hassle in the swap trying to remove mine. I can make sure it will make a seal with the auto one if you want me to.
Boot looks a lot better than the old one, still need invest in a new one too.
Harman850T5
Car: 2003 350z
Re: (Harman850T5)
Postby biggie » Sat Jan 30, 2010 2:49 pm
Harman850T5 wrote:If you can get a hold of a Matco dealer get the pilot bearing remover. Part#: CP55600
I'm pulling a 5spd pilot bushing, its too tight, so swapping with another one.
biggie
Re: (Harman850T5)
Postby MagikDragon » Sat Jan 30, 2010 2:51 pm
Go to autozone, rent a pilot bearing puller and a slide hammer and then return when done, it'll take you 5 minutes, vs a day with other methods.
-Sean
I want to live fully, very intensely. I would never want to live partially, suffering from illness or injury. If I ever happen to have an accident that eventually costs my life, I hope it happens in one instant.
—Ayrton Senna
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
Re: (MagikDragon)
Postby biggie » Sat Jan 30, 2010 5:13 pm
MagikDragon wrote:Go to autozone, rent a pilot bearing puller and a slide hammer and then return when done, it'll take you 5 minutes, vs a day with other methods.
Read a couple posts up, did that , the one from autozone is too big, have to get another one. But stuck due to snow/ice right now.
biggie
Re: (biggie)
Postby MagikDragon » Sat Jan 30, 2010 5:56 pm
are you sure you got the right one?
http://www.autozone.com/autozo...hment
thats the one I'm talking about, you cant just have the slide hammer, but you need to rent both tools seperate.
MagikDragon
Re: (MagikDragon)
Postby biggie » Sat Jan 30, 2010 7:07 pm
MagikDragon wrote:are you sure you got the right one?
Yep that's the one I have. The two prongs are too wide to fit in the bushing. The advanced auto one should work, it is narrower.
biggie
Re: (biggie)
Postby MagikDragon » Sun Jan 31, 2010 4:14 am
..s***, worked for me
If all else fails, and you cant get 1 in there, I've used a pipe wrench and twisted it.
I know its a b****, but it works.
MagikDragon
Re: (MagikDragon)
Postby krash » Sun Jan 31, 2010 5:42 am
why don't you just break it and pull it out in pieces?
biggie wrote:IIRC isn't there a shift lock connect at the ignition you can disconnect to stop it from locking?
Theres that green box thing under the dash. It was bolted to the hole that the top of your clutch pedal assembly is now bolted to. I left it plugged in and the key unlocks just like before.
krash
Postby biggie » Tue Feb 02, 2010 4:41 am
Picked up the pilot bushing puller from Advance Auto again, looks like it should fit. Probably will try this weekend, as it looks like I'll be snowed in again.
biggie
Postby biggie » Sun Feb 07, 2010 8:53 am
Small update. The Advance Auto puller worked fine. Got the bushing out, then got lazy. Gonna wait til next weekend for some tools/help, hopefully will wrap it up then.
biggie
Postby biggie » Mon Feb 15, 2010 3:33 am
Hey look a little progress. Of course something still had to go wrong, so a little trouble with the tranny mount/bolt, but got it in.
Just wiring and putting interior together left to do.
biggie
Re: (biggie)
Postby krash » Mon Feb 15, 2010 4:12 am
sweet, slow progress is still progress
krash
Postby biggie » Mon Feb 15, 2010 4:51 am
Yeah, I'm slow. Guess I also need to put the exhaust back on. I'll try to do that and put the shifter/center console in this weekend.
biggie
Re: (biggie)
Postby krash » Mon Feb 15, 2010 8:03 am
at least all the big stuff is done. you don't NEED to put the exhaust back on
krash
Re: (krash)
Postby biggie » Mon Feb 15, 2010 9:34 am
krash wrote:at least all the big stuff is done. you don't NEED to put the exhaust back on
Currently its unbolted at the exhaust mani, really would need to, it would drive me crazy.
biggie
Postby biggie » Tue Feb 16, 2010 9:47 am
Think I may go with the Isis shifter from Enjuku, try it out.
Ordered a lower boot to go over the shifter to contain fluids from the top and OEM plastic bushing to put on it. Will probably pack it with a little grease as well.
biggie
Re: (biggie)
Postby biggie » Sat Feb 20, 2010 10:44 am
Today:
-put the full exhaust back on
-filled the tranny with fluid
-fixed my seats, couple holes needed to be tapped and one custom bracket had come loose
Isis shifter came in, just got to wait on lower boot and OEM shifter bushing.
biggie
Re: (biggie)
Postby krash » Sun Feb 21, 2010 5:39 am
sounds good, I'm going to look into this isis shifter
krash
Re: (krash)
Postby biggie » Sun Feb 21, 2010 6:23 am
krash wrote:sounds good, I'm going to look into this isis shifter
I'll get pics of the install, probably next weekend. Seems good for the price so far, I just couldn't see all the $ for the b&m on a car that isn't driven much. And didn't trust the ebay ones (with holes not lining up, etc).
biggie
Postby biggie » Sat Feb 27, 2010 12:15 pm
Slowly...
Isis shifter installed.
Put on OEM bushing:
Packed a little grease in it and took off the weight:
Put on OEM lower boot:
Back together:
In car, RTV'd around edge and did have to lower the tranny crossmember a bit to get to the front two bolts:
biggie
Postby biggie » Sun Feb 28, 2010 3:24 pm
Steering column bolted back up, wires situated under the dash. Started wiring, confused a little while on what to do with the 2 harnesses, but belive its figured out, just have to do a couple more wires and put interior pieces back in.
Never noticed that the lower steering column cover is different than hatch/coupe, has a heavy piece under it (I assume to lesson vibration?), anyone removed it with results?
biggie
Postby biggie » Thu Mar 04, 2010 6:51 am
Just ordered this from walmart (with my $20 giftcard from buying Battlefield: BC2). Going to use it to mount the MDM-100 on the winshield and bring it down somewhere near the cluster or something without drilling any holes.
http://www.walmart.com/ip/Arko...52352
biggie
Postby biggie » Thu Mar 04, 2010 6:53 am
And hopefully wiring/interior will wrap up this weekend and it will run again. Then has to go under the knife for driver's taillight replacement and the rust/hole under batter tray issue. I'll update the title of the thread when that starts.
biggie
Postby biggie » Sat Mar 06, 2010 11:26 am
Got a few things done today.
Swapped Driver's taillight (it was cracked), that black stuff sucks.
Put shifter surround and lower driver's panel back on, will put steering column pieces on after the key interlock is tested that it doesn't lock the key in.
Started getting to the Rust/Hole under battery tray. Pulled the passenger fender, that was a huge pain in the a**.
From top:
From underneath:
biggie
PreviousNext
Return to 240SX Convertible Forum
