Forgive my lack of knowledge but why would the VDC warning light come on for low brake fluid or lack of pad? I would have guessed the brake warning light or ABS light . How are the two systems related?RED_DET wrote:Brake fluid is low or brake pads need to be replaced.
With my VDC problem, I'm well aware of those results! My light however, does not stay on. The link I suggested may deal that problem.HTTP://forums.g35club.org/zerothread/359479.RED_DET wrote:Simple, if the VDC engages for any reason, what actually happens. The power delivery is interrupted and the abs system kicks as well.
I know what you mean = I've spent many a day trying to give advice on the Altima forum based on what I learned from my Coupe.Sentientbydesign wrote:I really don't mind answering this question all of the time, but what annoys me is when we offer the correct answer and get people doubting the situation.
I told the guys in the Altima forum about the brake fluid being low probably because of worn pads and/or rotors and they argued with me as if I was stupid
The other thing that is annoying is when you take the time to answer someone's question - and they dont respond and let you know whether your solution helped them or not.Sentientbydesign wrote:I really don't mind answering this question all of the time, but what annoys me is when we offer the correct answer and get people doubting the situation.
This doesn't sound right. My understanding is that the VDC failsafe kicks in when you have low fluid levels. The low fluid levels are caused by one of two problems:austinpowers02 wrote:Yess!!! the responses for low brake fluid is correct!!! i had the same problem and after filling up to the max line for brake fluid, the brake, vdc and slip light went off. I was also told that a VDC sensor replacement can clear this problem for good ($140.00 for the sensor) or else you will prob have to fill the fluid back up in a month or so. 7/17/09
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
