themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Sat Apr 02, 2011 5:26 am
Start with the basics, got fuel? got spark? By fuel I mean fuel injecting. Your rail may be pupped up up but if the injectors aren't firing it means nothing. RB injectors, the top-feeds at least, are loud as hell; you should be able to tell. Spark, well, pull a coil and plug and lay it against the head and check. I've seen old platinum plugs die after sitting. I have no idea why, they just do that sometimes. If you are seeing spark, though, they are good enough to get a sputter.
You should have been nowhere near anything that would have caused a no-start situation.
