float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Thu Feb 26, 2009 9:24 pm
OK, I figured out what's up with the pin numbers.
If you go through every diagram in the FSM for the dash plug and write down the color, pin number, and description, you get the list that Bart put together. Something is wrong with the FSM though, because, at least on my car, those colors don't actually end up at the pins that are numbered out for that plug in the foldout.
Regardless, it's not hard to figure out what goes where and all of the color/description combo's are correct.
It wouldn't be the first time something like that happened. I know there is a typo in the FSM for the CA18DET for testing the ignitors that I'm almost positive is wrong.
