Agreed! I can't wait to get all these "bits and pieces" parts taken care of so I can get the big stuff like the clutch, flywheel and mounts and finally get this thing swapped in.srdub-t wrote:dam looking good! all the little nuts bolts gaskets and new parts must be nickle and diming you to death.
A little FYI for you, you got the hose on the wrong tube on the throttle body. The hose you have running from the nipple on the sensor housing goes to the throttle body nipple right below the TPSpositronone wrote:
Exactly, you think these small parts are so cheap but then the tally starts to add up and you start sweatin'! I am going to redo the waterpump studs, I did that on a wheel stud once so I should have remembered that so thanks. As far as the hoses go I know that I have way too much hose on there and that I have pretty much no idea where most go. I have been looking at pics of engines online and looking through my magazines and FSM to figure it out but while we are on the subject I have more hose questions.Hijacker wrote:That was the issue on my build. Nickle and diming. It all adds up way too much in the end. I had an order with my nissan dealer that came out to over $230, and that was with a 40% discount off list from a friend that works there. That order included timing chain, guides, guide bolts, random gaskets, random hard to find bolts and studs, and other little miscellaneous stuff.
I think I spent well over $50 getting all the little studs that hold the valve cover down. And then it's about $3-4 for the washer/nuts that you screw on top of the studs.
Also, I would have done the old two nut screw method for seating the studs on the water pump pulley. Take two nuts and thread them on the stud, then tighten them against each other and you can use them to tighten the stud down into its seat.
Duffman could have saved me a lot of trouble...and cussing........and spitting!duffman1278 wrote:A few things. I broke the little yellow piece as well, and to put them back in is a PITA!!! From what many people have told me their not even necessary.
For removing the injectors, theirs also a much EASIER, and cleaner way. Just remove the caps from the injectors, stick the screws back in almost all the way, and get a stick type of tool like an allen wrench that fits in the side holes of the injectors. Place the allen wrenches or w/e device you use and mount it on the screws that hold the injector caps, like a "V" shape and push down on the allen wrenches. Do it slowly, and it'll pop them out nicely. You might crack a little bit of it but it'll see be good to go afterwards.
One other suggestion, when you put the injectors back in, I used a socket that would fit inside the circle area perfectly and put the wrench on it and pressed it right in the middle. Thats just a suggestion though for anyone who needs this.
LOL. Was your oil filter plate designed for our SR or is it just a generic summit racing one? I'm not sure why the fitting wouldn't work. Keep it up with the part #'s I'm going through your build thread and compiling them as you go. Once you are done (are we ever ) I was going to give them to Hijacker to add to SR FAQ's/parts guide if the are not already in there.positronone wrote:Duffman could have saved me a lot of trouble...and cussing........and spitting!
It's a generic universal one which is no doubt the culprit.homeslicej2 wrote:LOL. Was your oil filter plate designed for our SR or is it just a generic summit racing one? I'm not sure why the fitting wouldn't work. Keep it up with the part #'s I'm going through your build thread and compiling them as you go. Once you are done (are we ever ) I was going to give them to Hijacker to add to SR FAQ's/parts guide if the are not already in there.
Ebay FTL indeed...when will I learn? Where can I get this port you speak of?Hijacker wrote:ebay ftl Since I don't intend to run an oil temp probe, I'm just going to get a dual port attachment for the stock port for the oil pressure switch. That way I can run a pressure gauge and keep my dummy light.
I might steal this to show. that is exactly how i set mine. and people are telling me my timing is off.positronone wrote:I swapped out my busted crank angle sensor.
Tools needed:ScrewdriverSocket wrench 12mm socket27mm socketOil
This sensor was fine when I got the motor...don't ask me how it got busted because I don't want to talk about it.I got another CAS from a forum member and at a great price too.If you look on your crank pulley you will see a group of little notches on one side of it, these are the timing marks. Use the 27mm socket and wrench to move your crank pulley to the notch that is second from the left, this is TDC or top dead center.You'll need a 10mm socket to remove the valve cover bolts and the valve cover so you can see where the timing marks are on the crank angle sensor.If you look closely on the CAS you will see a notch on the bottom and above that notch on the shaft you will see two circles, one on the top and one on the bottom. These are the marks that you will use to set the timing to TDC later.Use a 12mm socket or a screwdriver to remove the two bolts holding the CAS in the block.Take a moment to look at where the timing marks on the CAS are at TDC. The second circle or timing mark on the shaft of the CAS is aligned perfectly with the notch on the lower part of the CAS. This is how I want the new CAS positioned.Grab the CAS and tug on it until you pop it out.The new and the old. Dip the replacement CAS in some oil before you insert it back into the block.Now for insertion. This is what has to happen, you line up the first circle on the shaft of the CAS with the notch below it and when you insert back into the block the gears will turn slightly causing the second circle or timing mark to become aligned with the notch putting you at TDC.I lined the first timing mark up, inserted it and it lined up perfectly with the second timing mark.Hopefully I won't have to adjust timing when I start the engine up (that is if it's a good engine...man I hate to think that I could be doing all this for nothing) and it'll fire up the first time.
