Well, last winter I built the internals on my RB25 using CP pistons and RB26 rods. Instead of using the supplied wire locks with the pistons, I used the stock RB25 wrist pin c-clips to hold the wrist pins in. I only did this because I couldn't figure out how to get the damn things in there, and was in a hurry. I've heard of other people doing this with no issues, so I figure what the heck. Well, it went for about 2,000 miles. The c-clips were moving around inside the slot and eventually wore the slot down until the bottom of the piston actually cracked off. The wrist pin then slid against the cylinder wall and gouged a big groove in it. The groove was deeper than 1mm, so boring was out of the question.gawdzilla wrote:very nice build. props for getting it done so fast too. what happened to your original motor? how did you crack a piston?
Not really... you have an idler and a tensioner on a stock rb30/rb25. he drilled out and tapped the third hole to mount another tensioner instead of running an idler. correct me if i am wrong!Kalypso123 wrote:I know you can do it, and it'll be exciting to watch.
Im an rb amatuer... what about the tensioners?
you can choose which arrangement you'd like to arrange them in - am I right?I see there are three places to mount them.
Don't even go there. But I really don't think I'm in that boat. I've had blow by since day one after the build and I've never pushed it that hard. I pushed my 25 way harder without issues like that. But I will do a compression and leak down test just to make sure.Shocker wrote:As for the blow by I had this issue as well... it ended up being melted pistons. Check your compression then do a leak down test on a warm motor.
Hey I'm with you man, I hate going there. I cringe when its time to get the ole' compression/leak down tester out. But its an easy step to eliminating/diagnosing your problem. I hope for the best, I love your build! good luck.cdorhout wrote:Don't even go there. But I really don't think I'm in that boat. I've had blow by since day one after the build and I've never pushed it that hard. I pushed my 25 way harder without issues like that. But I will do a compression and leak down test just to make sure.
