hangout, you may find the following site a very informative read:
http://www.netcrafting.com/car_mx/pathfinder/oil.html
Basically, the right hand valve cover has a poorly designed baffle drain. This can be a potential cause of your oil consumption if you have no visible leaks. Also, a power valve screw backing out and being sucked in by the engine is also a possibility I believe (someone correct me if I'm wrong about that statement). You can check the condition of your power valves yourself by removing the upper intake manifold, there's a good guide
over on NPORA if you are confident enough to do this yourself. I think no matter what you should get threadlocker on your power valve screws if you haven't already, I think it runs for about $275-300 at the dealer. Not sure about tackling the right hand valve cover yourself, however. Maybe a leak down test is your next step. I have 123k miles on my PF and no oil consumption yet AFAIK. I really should check the oil level more often, though.
