my new 96 with notch top sr20
lucky03602
Car: 96 d21 *work in progress*
01 xj Cherokee auto 4.0 4 1/2" lift 32x11.5x15 family dd
hopefully the pictures show!
123,838 on chassis. the previos owner over rev'd the engine and broke some rockers and now cylinders 1 and 4 have low compression, like 60ish. im currently making a deal with another forum member about buying a notch top head off him complete nothing wrong with it, so hopefully the deal goes through and theres half the parts i need. hopefully the pistons are ok!!!
matt_240sx
Car: 1993 240sx Hatch
Dude, your wheel is upside down.
lucky03602
thats easily fixable, and thanks for noticing
matt_240sx
No problem, other than that, nice S14! :)
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
sleepah fa sho..do some work
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
nice, how much $$ you pick it up for??
lucky03602
badbob, 2k only!! and i dont completly agree infiniti_lineup. yes theres definetly some work to do, but as far as already having the engine installed, and ran great for 5k miles i have alot less then if i did the swap from the start, and alot less money too!!! gotta look at the brite side!!
so far 2k for car, 200.00 for comlete head being shipped to me tomorrow from florida
badbob2121
i agree, 2k is a deal...
sounds like you know what you are doing and have it all mapped out... good luck and post the progress
lucky03602
i can say i have a decent idea on how to start, but when we tear the head off ya never know what we going to find! step one is getting the engine mechanically running good weather thats before snow is on ground or this coming spring.
Dr.feelgood
Car: 89 240sx hb
whats the diffrence between nocthtop and regular sr
ArcherV20
Car: 1995 240SX
lucky03602
feelgood you should use that big search button on the right or just go to the rwd sr forum and go to the sticky that tells everything about them
rwd-sr-faq-version-2-0-t306956.html
lucky03602
so went outside and gave my car a quick once over to see anything aftermarket that was done, no name fmic with 2 1/2 piping, turbosx bov on hotpipe, and custom exhaust from turbo down. what i mean by custom is its 2.5ish inch piping with no muffler, cat, or resionator all the way to a 2.75" tip, good welds though ill have to admit. in cab is boost gauge and air/fuel ratio. cant quite get under car to see how he has the ratio wired in..
stock suspension and steelies with hub caps. the sr does have a/c though which i thought was funny. electric fan wired thru a aftermarket relay. looks like ka radiator.
lucky03602
so i ordered a perfect head off our forum's classifieds, paid 200 and its shipped and should be at my house this week. also did a side tree job so i got some extra jingle in my pocket off to the side so i can buy arp head studs, cometic head gasket and rocker stoppers. i think im going to get the thermalnator mani gasket also. since i dont believe they did anything to the engine before swapping it in does any vets recomend anything to replace that involves only taking off the head??
Morph
Car: 91 Sr Powered Coupe
If i were you wouldn't use a cometic HG. My self any many other members have had issues with quality and have had to replace them after a few thousand miles. I ended up going with a Cosworth HG and havent looked back since.
lucky03602
thanks for the info, ill take heed of your advice :)
