I began another project.
Its a 89 s13 coupe base model.
Already got the horrible pop-ups gone.
Engine bay is already cleaned and painted. I removed all the wiring.
I started messing around some with the wiring for the bricks. Trying to decided how I want the fogs wired.
The new silvia front has bricks, Tomei corner lights, Tommy Kaira grill, oem fenders with a mega roll/pull, used hood, oem front bumper, hippo sleek front valance (matching side skirts), and im re-using the headlight brackets from the wreck.
Got the body harness pulled out. Im going to be doing a tuck. Fuse box will be behind the radio, and headlight wiring, ac wiring, lower harness, and wiper plug will be ran through where the upper harness comes through the firewall.
I pulled the dash to run wiring for body harness, gauges, boost controller, turbo timer, etc. I have an uncracked HUD dash with HUD unit and gauge cluster with a 9K redline tach from a jdm cluster that will be going in as well.
Finally got started on the oool trusty sr20 last night.
I think it had a small exhaust leak...
took the head off
Arp head studs and Apexi headgasket went on
got the motor Re-assembled. But had an unfortunate incident with the headgasket and the front cover. I will be dissasembling the motor again for a new Coswoth gasket.
Bought a new seat. It's a carbon fiber cobra misano seat. Not a fan of the color with black interior. Probably going to dye it.
Bought some jdmtyte Superstar 3-piece wheels that i will be drifting on. Shopping for some 5-inch lips.
Ruberize undercoated the underside and wheel wells and did the front 5-lug and z brakes. Have a lot of suspension parts to order. Sucks that most everything PBM has is out of stock right now.
Re-sprayed the engine bay sunrise red. Grinded off any surface rust. Also got my fenders in finally
Installed the bricks and Tomei corner lights.
And put on the Tommy Keira grill. Needs to be sanded and prepped for paint, and needs the badge made.
Got some more parts. Bc 264/264 cams, Bc valve springs, Bc titanium retainers, and Cosworth head gasket. Ignore the intake manifold and clutch. Thats for a different car.
Also I put a lsx in my hatch...lol
jk its for my friends s14
