95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sat Feb 10, 2007 6:27 pm
check the ABS relay....., that is the first time i hear of such a case on a J30, but alternator going bad over and over means that there is something that is over draining the battery/alternator when the engine is on.
the ABS relay is a common problem with the J30, and it does drain the battery, but that would happen even if the engine is turned off
a bad connection to the alternator is also an option, if it is shorted at any point, or if it is not connected loosely then it could cause the alternator to fail, but 5 times??, again i doubt that this is the problem, but check it anyway, a good sign would be if the lights flicker when the engine is on, also dimming of lights while driving
the headlight relay could cause a battery over drain when the engine is on (if it is a bad relay), so check that also
a very slight chance, but it could happen, is that the starter stays on for a while when the engine is turned on, which can really damage the alternator, i've seen it happen but not with the Js
i dont have much experiance with electrical, but that is what i can think of, run an ECU diagnostic, and tell us what you get, keep us posted
