Here is a link to the promised pictures:
https://skydrive.live.com/redir.aspx?ci ... aCC!Avc%24
Here are a few extended comments on the photos:
1. Murphy's Law corollary: The more you try to isolate any one thing, the more you find it connected to the whole world. Nissan Engineers wholely subscribe to this.
2. Head lamp assemblies after removal, one upside down to show the location of the ballast.
3. Ballast un mounted showing the internal routing of the high voltage cable and intergral moisture seal.
4. The OEM connector and bulb. Since the kit came with different connectors, I cut off the connector to facilitate removal.
5. The kit as delivered including bulbs, ballast, power connectors, tie wraps, two sided mounting tapes, and useless instructions. Supplier does have a good video on YouTube.
6. While the new cable was long enough to run internally per OEM, sealing the hole was going to be difficult.
7. To ease installation, I fabricated a block that mounts in place of the old ballast allowing an RTV seal of the old hole and a flat mounting surface for the new ballast. I drilled a new hole close to the bulb so I could run the high voltage cable externally. Mounted the ballast with the doublesided tape and spliced the new power connector to the old wires. OEM Green (+12v) to red and OEM white to black.
After making the mounting blocks, installation was straight forward and went without a hitch. Output voltage and power of the new ballast matches the spec.s labeled on the OEM ballast. So far so good.
