Socaldiablo »
https://forums.nicoclub.com/socaldiablo-u163627.html
Wed Dec 22, 2010 10:45 pm
Mclovin,
You've got a bad IPDM. Swap it out for a new one ....should only cost you about $130 or so if you do it yourself. Dealer will charge you closer to $400. I think, however, there may be a recall for a relay associated with the IPDM and you may have your dealer fix that at no charge. You might want to research this issue and see what the dealer will cover. Otherwise, just replace the entire IPDM unit for about $130.
