evildky »
https://forums.nicoclub.com/evildky-u13100.html
Wed Dec 22, 2010 1:43 pm
putting fuel in the filter won't do much if there is air in the lines, it takes a while to pump fuel through the lines
as for the carbs, the atf viscosity might slow the pistons too much especially if it's cold, the level shouldn't be an issue as if overfilled it will run into the intake
have you messed with the carb jet screw at all? have you had the floats out? sometimes the drain hole at the bottom of the float bowl or the fuel line itsef that leads from the bowl to the jet will get clogged, you can try fillinf the float bowl with fuel through their vent holes and see if it fires
I was asking if the distributor has been removed, as in no longer clocked properly meaning incorrect ignition timing, as for the point, if you have the stock distributor then you still have points and they need adjusting fomr time to time
the wiring ont he strock 240 is pretty simple, you should have constat 12+ to the + side fo the soil when cranking and the - side should hook to the single wire coming out fo the distributor and the tach wire also hooks to the -side, there is a ballast in there that serves to drop the voltage
