DanielC »
https://forums.nicoclub.com/danielc-u110482.html
Wed Dec 31, 1969 5:00 pm
Here is an update on the progress on My 521. On Wednesday, two days after I started this project, I got the most promising L-16 free up and to turn, after letting it sit with penetreting oil, and ATF in the cylinders. I sealed up the openings that do not normally have water in them, and pressure washed the engine, and occasionally myself. I then bolted a transmission and starter to the engine, and hooked up a battery so I could do a compression test. The compression test came out as follows: #1, 60 psi #2, 75 psi #3, 120 psi #4, 60 psi. I think I need a little more than that. I put more penetrating oil, and ATF in the cylinders, and let it sit until Friday.
On Friday, did another compression test. The compression test came out as follows: #1, 70 psi #2, 77 psi #3, 140 psi #4, 132 psi. There might be hope for this engine. More penetrating oil, and more ATF. I hope the reason for the low compression is that some pistion rings are stuck on cylinders #1, and #2, and the oil will loosten them up enough to maybe get the engine to start, and running the engine will finish the process of freeing the piston rings.
I have started exploring my other options for getting the truck running again. I talked to a local Nissan dealer about parts availability, and pistons, rings, bearings, and other internal engine parts are listed in the parts information they have. A local outlet of a national auto parts chain has remanufactured engines, and short blocks available. The parts person at the local Nissan dealer also suggested the possibility of putting a more contempary engine, The KA engine used in the 1990 to 1997 hardbody pickups.
Here is what I have found for parts, so far. I live just south of Portland, Or, so some parts sources may apply only in my little world around Portland.
For bolts and fastners, i have been going to a company called Oregon Bolt, INC. They have had every fastner I have wanted so far, at prices well below what you would find at any "big box" home hardware store.
The local Nissan dealers have oil filters, current part number 15208-43G00, for $8.48
I got an Engine overhaul gasket set from another local auto parts store, Clackamas Auto Parts in Oregon City. The Gasket set was made by ROCK, the number is FGS6033, the price I paid was $58.00
I have a lot of parts with rust on them, I am experimenting with a process of electrolytic rust removal, using a battery charger, and some reasonably common household cleaners. I will let you all know how that turns out, soon.
