spitalul2bad »
https://forums.nicoclub.com/spitalul2bad-u98702.html
Tue Jan 20, 2009 8:40 am
Finally, my mods have arrived (shipping took forever), and I have enough free time and cash to get them bolted onto the car. The build started today and the car is still in the shop because we got into trouble when changing the headers and it will take another work day to finish it all.
Here's the modifications I bought:
Injen CAI (using it as a short-ram for fear of water getting into the engine)DC Sports HeadersMegan Racing CatsHKS Cat-Back True Dual Exhaust (titanium tip one)QAS Lightweight FlywheelQAS Short ShifterMotordyne MREV 2 ManifoldMotordyne 5/16 Plenum SpacerUnorthodox Pulley SetECU Reflash for all the mods (V-Max restriction off, plus knowledge of the installed mods)
For the future, I am looking into changing cams (maybe Tomei) and final gears to 3,9:1. The car will remain N/A.
Warning: The photos are VERY LARGE. I did not scale them down because I thought some would want them at their full size. Hope you like them. It will take some time to load.
So, here goes:
These are the boxes...
Discreet 'megan racing' logo...
Motordyne is present...
Unpackaging the headers...
The MREV2 and the spacer kit...
The Injen CAI and a hood support (to skip using the OEM strut support)...
DC Sports headers...
Megan Racing high-flow cats...
Unpackagin the great "beast" of a box... the HKS exhaust...
Beauty, isn't it?
The titanium tip...
All laid out...
Car is prepped for mods. Hood is taken off.
Easiest job: the MREV 2 and the spacer...
Removing the old one...
Installing the Motordyne one...
Closeup of the almost-finished MREV 2 + spacer...
The screwes have to be tightned and away we go!
View of the injen CAI going in...
The air flow measurement...
Fitment test...
Spacer for the CAI...
Adding the cone filter... thus making it a short ram and not a true "cold air intake". I'm taking the safer route, don't wanna risk water getting into the engine...
Old exhaust going down...
Getting the O2 sensors off the old cats...
The carbon driveshaft...
Removing the gearbox to change the flywheel and the shortshifter...
Getting the old shifter out...
Replacing it with this...
It was wedged in tight...
View of the rear diff...
The gearbox is easily removed...
The clutch assembly...
The old flywheel...
Flywheel comparison. Left (old), right (new)...
Nothing left
The headers are hard to get to... it would have been beter to remove the engine but I didn't want to do that so we had to remove the alternator, oil filter and loosen a lot of things to finally get those old headers out and put in the DC Sports new ones... This took from 11:00 am until 15:00 when we called it a day and went home (we started around 7:00 am).
One of the headers installed...
Left header is the new one, right is the old one...
The day is over. Tomorrow, she'll be reborn...
DAY 2:
The following day the header work finally ended. Added the cats and then the HKS true dual exhaust. The HKS had BIG problems going up... although made for this very 350z model it did not "bolt on", it had problems passing the rear diff. With some 3 hours of labour of adjustments, it finally went up.
I am NOT satisfied with the TIPS of the HKS... the bolts look like crap.
Here are the final two pictures... FULL exhaust:
Modified by spitalul2bad at 1:24 AM 1/22/2009
