around 390whp with 11.5 psi i believe if i remember correctlyGold Digger wrote:Not bad but it looks like a bug-eyed freak of nature.
What kinda numbers are you putting down with it?
i havnt boosted it higher..will be getting another tune this summer and will tune for higher boost..im running stock bottom end i dnt wana push it too far
yee..this is a r33 engine 95no collar issue also i dnt rev it more than 7500 thats where my limiter isim only going to take her around 450whp i guess for street driving cuz i dnt want to ruin the motor..then maybe next year ill get a fully built engineGold Digger wrote:
Not bad.
The stock bottom end is good for like 550-600 if I remember correctly. Any idea what year the engine is? 95 on, Nissan addressed the crank collar issue on the RB engines. If it's a an older engine, you might want to get that taken care of.
yee they are pretty soilid motor but going past 600 without a rebuild is kinda a ticking bomb dont you think..im just playing on the safe side..probly 550 max thats hp not whp..did not replace the springs and valves but seems going well for meGold Digger wrote:Dude, the stock bottom end is pretty solid. You can run a stock RB26 to 8K all day long and it just begs for more. They are very well built engines.
With your cam set, did you replace the springs and valves?
I have heard issues with the 264 cams not working well without replacing springs and valves. It's just hear-say, but I hear it a lot over here.
I haven't done anything, yet, to my V-Spec, but I have many years to build her up. Gonna shoot for 500ps as a goal, which won't be too hard.
