this is my 240sx... my project starts maybe 2 years ago... so i put engine in there but there was some wrong things with the install and i decided to do it better than the first time. i will buy an solder machine to do stuffs but i never solder anything so i need to learn how to but i think its not hard.
before the engine changes.. they will be outside changes.. a great bodywork will apreciate.
first off... my actual car..
clearance between radiator and water pulley
engine mount and oil pan .. its to dirty
actual carburator and intake .. edelbrock 600cfm and torker II
my car this morning.. yea.. i open the hood and put a piece of wood in there because the first person who install the engine... took the steel piece and put in the tranny shift pod.
look at clearance between tranny bolts and the tranny hole... the engine its mounted horizontal and maybe if i let it drop the back a little, it will be sit better...
an other one
see the square piece of wood in the engine mount.. i put it there because the engine was sit higher at one side.
radiator fans, yea ... the car is nissan...
i want radiator fans in the right place because this city its to hot in the day all the year. some times hits 45 C
yes, stabilizer bar hits the pulley every time when car is lifted. but when the car is down, it works fine.. but its a problem so i will fix it... see the oil pan.. its to down... one time i hit a rock in the street and broke the oil pan.
tranny was mounted to high... and the exhaust system suc** .. its fine when u do the job and thinks goes wrong... its bad when other do the job and all suc** ...
spoiler or wing.. i dont know but i like it.
radiator and electric fans
see carefuly this picture.. i will take the engine pulley and quit the last "V" thing... and short it from the beginning
i cant take off this piece... i dont have a piece that take of a big bolt
i pay 3 bucks to my brother .. he was cutting the exhaust
with this.... cutting tool without the ... see for ur self
wing or spoiler
another one..... .. see far far away...
one more...
i put some pieces of brake pads to lift the engine mounts and see how high can i lift it ...
after i mod the height ... it looks great... i take notes and try to do new engine mounts.
if all things will going good oil pan will be more at the back and with this height
im asking for manual tranny costs because i will do a auto to manual swap too.
please.. give me some advices with all stuff i show you.. and some others with the electric wires.
how back can i mount the engine or how back its recommended distance?
i will purchase cams for my engine too =) on tuesday.
thanks.
Street Elite all the way!! (Your top speed is our 4th gear)
