medjohnson77 »
https://forums.nicoclub.com/medjohnson77-u60654.html
Sun Jun 17, 2007 5:49 am
hello,
I don't know if this is your problem, but I have posted awhile back on the same issue with my 95 maxima. I had changed out the pos. cable that attached to the post, made it a solid connection instead of the three wire connector. I tested all my relays related to the ignition system. Had my starter checked 4 times, it tested good all four times, But the start problem got worse and over time it fried my starter, i had to replace it. I got so frustrated that i made an app. with the nissan dealer here in Bloomington In. When i talked to the service dept. and told them everything i had done to it, one of the machanic's got of got a real smug look on his face and said well, it sound's like you need a new Nissan starter for $330 dollars, + labor which would of been about another $150. Wow, i thought it takes me 15 min. to change out the starter, $150 in Labor hey, WOW! He then said if thats not it then we can fab. a ground wire to the engine and tranney all for the bargin price of $168.00 dollars parts and labor. I went to lowe's and got the cable and hook ups for a total of 10 dollars and 15 min. later had it installed. Needless to say i never made it to my app. with the ripoff dealer.
Heres the kicker, I have a buddy that referred me to a machanic here in Bloomington and he only charges $55 dollars a hour for labor. He started checking the Relays and about 20 min. into it, right before he started to check the wiring harness for shorts, i told him i had read an forum that a guy had the same problem that i had, start some time and others it wouldn't, and to let me try something real quick. I took apart the stearing column and i had already done this a month ago to put a new ignition switch in which didn't fix the problem. I unscrewed the two little screws that hold the switch in and pulled out the cyl. that accepts the little tab that is on the key cyl. itself. I took a piece of cig. foil and tore off a small piece and double it over, and slide it up on the tab in the key cyl. on the left of the column. Then i slid the switch back on and put the two screws back in... Sure enough, it cranked! Shut it off and re-start 6 more times. I told the machanic what i had done, he said he would of never found that. He would of just replaced the key cyl if he couldn't find any shorts or if the CPU wasn't bad. So I am not saying this is your problem but after regrinding all my grounds and every thing that i have done sorting out the bug, I WOULD TRY THIS FIRST THING! the tab looks like a "T" and isn't even a metal to metal connection. I just wears down enough that it wouldn't turn the switch far enough to start the car everytime. Nissan has to know about this problem, but instead of taking care of it for very little, they would rather talk about the bendix in the old and rebuilt starters and try to charge around 600-1000 to fix something that cost me $3.65 for a pack of Marlboro's and 15 min. of my time. No wonder the machanic at Bloomington Nissan had such a smirk on his face, They must of thought i had SUCKER WROTE ON MY FOREHEAD.
I hope this help you,
Winston
