ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Jun 24, 2011 9:49 am
Battery and brake are tied together by 2 diodes and then tied to the AT temp fluid, a combination that can be energized by a single fault issue by the alternator.
The battery light generally lights when current is reversed, the brake light works via low brake fluid and parking brake applied.
To have all 3 at the same time is a possibility. but not probable.
As an educated guess the problem may be stemming from your alternator, why? The diodes are not affected by DC but by AC and the alternator could be failing or leaking with an AC ripple into the DC via the rectifier built in.
Examine the alternator connections and test the output. A good multimeter can indicate the AC ripple or a failed or failing diode within the rectifier.
In the mean time disconnect the battery + and - leads, verify the - is having a good ground connection, then verify the + lead is not having a reading. It must be oV with battery disconnected, no voltage from the alternator.
After about 15 minutes and tested good, connect the battery. If your battery is 13 V or lower charge it with an independent charger to float voltage, then hook it back up.
With a charged battery, start the vehicle, then listen to the alternator, a meter on the terminals of the battery on DC should read from 13-15 V, no higher, try reading the voltage on AC, should get nothing, but if something the alternator needs examining.
Listening to the alternator you are listening for a high pitch frequency that should not be there since you have charged the battery, if there, the alternator needs work.
If when running you are much higher than 15 V the regulator is shot, but it could be a failing rectifier causing it.
