kblast523 »
https://forums.nicoclub.com/kblast523-u8596.html
Tue Jan 13, 2004 5:58 am
That is true, but I doubt a syncro is making noise first thing in the morning while traveling in gear. A syncro will "whine" if it is pressed too hard while changing gears and that is normal. A whine while while driving indicates a bearing that is imperfect and has either eroded surfaces or contamination. If iti s in all gears, its in the final, or maybe some of the hilical cut surfaces n the gears themself are at fauult. The only way to tell is to pull it and take it apart. The first post in this thread points directly at the first gear shaft bearing (99WhiteSe). The only way to fix that one is new parts, hopefully before a total transmision failure occurs (inevitable). The second phase of this post (574-240sx) probably has a gear that came out of a different set or has worn in abnormally. I am not familiar with what lube goes in the 240SX trans, but I am running ATF in a 1992 Ranger with 134K and no whines, no grinds etc. I had a 1990 Ranger that got noisy at 90K, and I switched it to 5W30 syn-blend motor oil (imporved syncro action, just like an overhaul) and all was well when the truck departed my ownership at 155K. Either way, the fix ain't cheap.
