Q45tech wrote:Congradulations, your lack of sunroof mainteance [lubrication and rail cleaning]
Actually, Q45tech is merely pointing out that without maintenance, systems fail.bullitandy wrote:Rude and unnecessary-especially from a senior member and moderator.
It was rude, and your response makes you sound like a know it all and a jerk. Perhaps the guy recently bought the car. Did his lack of maintenance cause it to fail? Perhaps the sunroof has been regularly maintained and failed anyway? Perhaps if you merely told him what you thought was wrong without all the finger pointing and hubris this place (and you) might not have such a lousy reputation.Q45tech wrote:Why is it rude to point out the truth. I didn't cause it!God did not cause it.Nissan didn't cause it.THE OWNER CAUSED IT!Owners must take responsibility for their own short comings and lack of automotive education. They chose to own a 15 year old vehicle they must be prepared for the results.Pain and Punishment.
What product is recommended for lubrication of said rails?Q45tech wrote:Congradulations, your lack of sunroof mainteance [lubrication and rail cleaning]...
Clean the rails first, then lubricate lightly with white lithium grease.DoinkMobb wrote:
PB Blaster works good as a penetrant to loosen up the dirt but it's thin and will be gone in a week or two. Once it's all cleaned up with a penetrant then a coating of lithium grease will stay around for a long while.Paul Wall wrote:try some PB blaster too.
Thanks for the excellent tip about the candle-I've always thought that grease replicates the problem and have tried graphite powder but am excited to try this method.texasoil wrote:the links are cast pot-metal (aluminum?) and are not strong or flexible--be careful. THe drive cables are very robust coiled springs with packed fiber (lube and kink prevention) driven by a toothed wheel (gear) on the motor assembly--foolproof--if the slides are kept free of grit. I suggest complete cleaning and then rubbing all the sliding surfaces with a DRIPLESS candle. The dripless candle is made of stearic acid which is an EXCELLENT luricant for aluminum sliding surfaces. Dry film, won't attract dirt, etc.
