I'm from Singapore, and have owned my 180sx for the past 7 years. Ran the stock CA18det in the early years, then dropped in a SR20det, and now I'm back a full circle with a rebuilt (new oil and water pump, bearings, hone + rings, ARP head studs, deck + Cometic HG) JDM CA18det
I've learned alot from this forum when I was researching about how to go about with the rebuild, so thank you to everyone who shared their experiences.
I'm in the process of running in the rebuilt CA18det. She starts, idles and runs well, and pulls fine without any hesitation. The only thing is that there are random momentary dips in power, these can happen under any situation, be it accelerating, coasting, constant throttle etc.
You can feel the engine stumble and see the rev counter dip, before it picks up again. I believe the problem is electrical as I've hooked up a self made red-green flashy light diagnostic box to my dash - every time the power dips, the diagnostic mode resets itself to Mode 1, so I believe one of the 12V lines going into the ECU is dropping momentarily, causing the ecu to turn off and on.
Another thing to note is that I am running SR20det ignition coils on all four cylinders, as 2 of the old CA coils were faulty. I used the SR coil sub-harness, CA coil rubber boots and used longer bolts with the CA coil pack plastic cover to press/keep the taller SR coils in place, the CA ignitor module is still in use. Internet info about the CA and SR dwell times seem quite close, and this setup seems to work fine, but I'm not sure if this is a source of my problems until I can get a replacement ca18 coils to try out.
Hope to get some views from anyone who has experienced similar issues.
Thank you
