This confuses me lol, who said anything about an alternative fuel source?qwertyz wrote:NO vacuum leak......... BOOST LEAK two different things.. you cant add an alternative fuel source when you boosting cause boost will push it out and not suck it in and also you driving... unless you on a dyno and you can spray soapy water on the pipes to see the bobbles coming out
rig up a tool for boost leak and find it
and dont tell me trying to add alternative fuel when idling, you will find a vacuum leak and you will fix it, but under 8 psi of PRESSURE you still going to have a BOOST LEAK somewhere else......
A vacuum leak, in most spots becomes a boost leak. If you spray carb cleaner at the cold side of the engine, around the fuel injectors, you will hear a change in idle rpm.julio wrote:This confuses me lol, who said anything about an alternative fuel source?qwertyz wrote:NO vacuum leak......... BOOST LEAK two different things.. and dont tell me trying to add alternative fuel when idling, you will find a vacuum leak and you will fix it, but under 8 psi of PRESSURE you still going to have a BOOST LEAK somewhere else......
lol: That comment was only in reference to it's legibility, not the concept.tyndago wrote:A vacuum leak, in most spots becomes a boost leak. If you spray carb cleaner at the cold side of the engine, around the fuel injectors, you will hear a change in idle rpm.julio wrote:This confuses me lol, who said anything about an alternative fuel source?
At idle you aren't going to have a boost leak. Under boost, you aren't going to have a vacuum leak. It is more or less the same thing. You possibility have a leak.
