Melted piston head gasket failure question HELP
rswails
Car: 1996 240SX s14 kouki conversion sr20det s14 notchtop
1992 Nissan 240SX rb20det swap
Hi guys,
I just bought a kouki with a notchtop zenki s14 sr20det engine. The guy before me had it about 4 years with same setup and worked fine except was running T28, and a different radiator. Then his radiator blew and he told me it ran hot once when it blew but didn't get all the way to the H on the temp gauge; thats when he put the KA radiator in. It was tuned very rich ( poured black smoked at WOT. The tune was done at 17psi, and it gradually went down to 15.5 psi after about 3 seconds of boost and stabilized at 15.5. I have wideband and I never saw any problems, it would stay at about 10.8 at WOT. I have an ISIS RS3871 turbo, stock HG, nistune with daughterboard, 750CC injectors, BC stage 2 cams, and walbro 255. I was running a KA radiator with a crossover hose with no shroud for the clutch fan installed.
After about 2 weeks of owning the car, I decided to go to an autocross. This was a pretty fast course ( got up to 80-90mph ) and on the second run I miss shifted from 2nd into 5th. I worried this might have blown my head gasket from possible detonation. I didn't hear an knock or feel any missing though. Anyway, while in line for my 3rd run, my car started overheating. I parked, and noticed my silicone hose right at the turbo compressor had a large crack in it. This of course could have created catastrophic lean situation and maybe caused my pistons to melt, and then cause my head gasket to blow. Of course, my improper cooling setup without fan shroud could have also caused my head gasket to blow I suppose.
After that I patched the intake hose crack, refilled my coolant and tried to make it home. It overheated again 20min later. And I saw tons of white smoke/vapor in exhaust and suspected head gasket failure at that time. Also was low on coolant. Towed it home at that point.
I think took the head off and noticed coolant in #2 and #3 cylinders. #1 cylinder was melted the most. Take a look at the pics below. I also have pics of the head gasket and you can see some damaged parts near the piston holes for #2 and #3 piston on the head gasket.
I know I am going to of course buy new pistons, check the head out and have it resurfaced, check scoring of cylinder wall, buy ARP head studs, get Cosworth 1.1mm headgasket, new water pump, and thermostat.
Question 1: Why do you guys think this happened?
Question 2: Can I reuse this block? You can see the block melted a tiny bit near the cylinder wall but is that a big deal?
Question 3: Do you have any other recommendation that I need to buy, or check?
Video of the 2nd run I did that day at the autox showing temp gauge, and AFR: http://www.youtube.com/watch?v=u3IQgF38hyg
Pics of 2 slightly melted pistons and head gasket, and block.
http://sdrv.ms/N5Cdrj
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
1. Improper cooling for your setup. Stock radiators aren't very efficient once you upgrade turbos, adding boost = more heat. Running a clutch fan without a shroud would definitely do it.
2. Get the block fully inspected by a reputable machine shop before you use it.
3. Bore will more than likely be at least .20 over.
rswails
Dude awesome avatar, I used to be da man at Killer Instinct and Saberwulf was my fav character! Also liked TJ Combo, and Glacier! Did you check out the video before you made this post?
Lobo240sx
rswails wrote:Dude awesome avatar, I used to be da man at Killer Instinct and Saberwulf was my fav character! Also liked TJ Combo, and Glacier! Did you check out the video before you made this post?
Thanks. I still got the game on Super Nintendo and Killer Instinct Gold 64. I used to work in an arcade in my younger years and killed that game. Personally though Killer Instinct Soundtrack > Actual Game. :D
Yes I checked the video out nice run you had going there. Car started overheating. You need a Go Pro outside the car.
S-tec Motorsports
It died from ping. Too much gas in a Sr causes it to start knocking. I run them more at like 12.2 at wot. Down close to 11.7 you have to dump timing to stop the knock. Which loses power. Could also just be too much timing, or bad gas, but that looks like a flame front problem hitting the piston to me. Think really hot blowtorch
