Sounds like a 3k (+-) based on skill level. i feeel that this is what you all are prodding at.PAintballa45 wrote:i dno about just dropping in a JDM motor after all of the custom stuff. You forgot to add in the radiator / mounting, intercooler piping, trans support, driveshaft and downpipe eli
edit: when my buddy called mckinney they told him you need a custom intake manifold aswell because the cold pipe goes over the motor, it will not clear the hood even with their mounts. big bucks.
You left out maintenance in that little estimate there... Figure in another 1k+ to get all the maintenance up to date, it is a JDM motor mind you so you should treat it like any other JDM motor.TTkickedin wrote:Anywhere close to 3k? certainly.
rb25det engine only = 900 http://www.jdmtigerjapanese.com/nissan- ... ts-93.html
z32 or rb ecu + nistune = 1000 (can run rb25 off vg30dett ecu, which either you should have OR can be had around 150-200.) and a new Nistune license would cost 700 installed or less.
rb25det bellhousing = 300 http://www.rawbrokerage.com/RB25DET-Man ... ousing.htm
vg to RB wiring harness = 500 from wiring specialties.
We'll call it zero, since it's just cutting and rewelding. Or maybe 10 bucks for a spool of welding rod, assuming you have argon/c02 for your welder and other necessities of welding.
the kit from them = 500
Sounds like you can do it for around 3200 to me, actually.
factoring shipping in, it has to be closer to 3500ish... but still, you said close to 3k. which, that still seems to be pretty close to me. And this isn't items on classifieds either, which tend to be cheaper.
NOT true, it all depends on how you mount the motor.bartZ32tt wrote:Don't forget, the rb is longer than the vg so you need an undermounted radiator - the stock one wont fit.
If going from NA to TT intake and IC piping is a moot point... Have you seen where an RB20/25 factory intake pipes for the turbo and manifold end up? It is almost perfectly in the OEM TT orientation so one could get away with using OEM TT pipes. R32's were single SMIC...bartZ32tt wrote:You'll also need custom intake/intercooler piping, driveshaft, exhaust, etc as well as no-brainer maintenance items like full timing belt kit, misc gaskets, clutch/flywheel kit, wiring harnesses, etc.
OHRLY? Explain how you plan to route the water lines when it's crammed in between the upper radiator support and the engine. The rb is a much longer motor - a straight 6 vs a v6. Guarantee you need an undermounted radiator unless you feel like hacking the front or rear of the engine bay.z32pilot62 wrote:NOT true, it all depends on how you mount the motor.bartZ32tt wrote:Don't forget, the rb is longer than the vg so you need an undermounted radiator - the stock one wont fit.
notice how far back into the firewall that engine is. Also notice the throttle body/intake piping being in the way of the stock vg radiator. This argument only applies when going from vgtt-rb - no existing intercooler piping to use when going na-rb. And even then, you'd still have to choose either the hot side or cold side to custom fabricate and you'd still be stuck with a frankensteined pos single side mount intercooler. Not really sure what argument you're trying to make here but my point is far from "moot"...z32pilot62 wrote: If going from NA to TT intake and IC piping is a moot point... Have you seen where an RB20/25 factory intake pipes for the turbo and manifold end up? It is almost perfectly in the OEM TT orientation so one could get away with using OEM TT pipes. R32's were single SMIC...
Proof, please. You can only mount an rb25 in a z32 so many ways. Most people would try to mount the motor as far rear-ward as possible for better weight balance/distribution rather than trying to preserve the stock driveshaft.z32pilot62 wrote: Driveshaft again depends on how you mount the motor, DOES NOT have to change.
Moot? It would still leave you with the task of creating a one-off piece vs choosing from a selection of new or used exhausts that'll fit like a glove. I guarantee I could find a used vg30dett exhaust for cheaper than what you could make a custom rb25-z32 one for.z32pilot62 wrote: Again going from NA to TT exhaust will have to change atleast the front half and with that I COULD leave my rear half of my factory exhaust as well on an RB so, moot point...
Sorry, but this statement is horribly wrong. Here is a highly detailed write up on rb25-z32 wiring. Feel free to count how many wires are needed to depin and let me know. More than 5? Soldering required? You betcha.z32pilot62 wrote: Wiring is not that difficult if you do a little research, it is literally depinning about 5 wires and switching them around, and adding 2 to the RB harness and it will run on the Z32 ecu.
Well, I truly hope you prove me wrong and I don't intend to discourage you; i only stand to inform. But please report back with the ending costz32pilot62 wrote:
TT swapping an NA is not cheap either but everyone seems to want to try and justify that it is "cheaper" when in reality it would end up costing me about the same as this RB swap that I am undertaking just to get a Factory TT motor in the car. Now going from TT to RB yes that is definitely working in reverse.
The way I'm planning to do mine is with the motor as far back as physically possible, run this: http://www.summitracing.com/parts/GRI-1 ... /?rtype=10 and E-fans on the front to maximize room in front of the motor. As stated before, I plan to run a single SMIC with OE piping and that should be more than plenty for the modest power goals I have for the RB20...bartZ32tt wrote:OHRLY? Explain how you plan to route the water lines when it's crammed in between the upper radiator support and the engine. The rb is a much longer motor - a straight 6 vs a v6. Guarantee you need an undermounted radiator unless you feel like hacking the front or rear of the engine bay.![]()
Notice how far back into the firewall that engine is. Also notice the throttle body/intake piping being in the way of the stock vg radiator.
Most people that are looking to do the swap the inteligent way yes would mount the motor as far back as possible, those trying to make the swap as simple as possible are going to just swap bellhousings so they dont have to change driveshafts and mount the motor a little farther forward. Like I said, depends on how you mount the motor...bartZ32tt wrote:Proof, please. You can only mount an rb25 in a z32 so many ways. Most people would try to mount the motor as far rear-ward as possible for better weight balance/distribution rather than trying to preserve the stock driveshaft.
Must be pretty expensive to get exhaust work done in your area then, downpipe back to a y-pipe before the cat back is what 4 feet? I was quoted $135 to do that on my Honda... But you are right, it probably wont fit "like a glove" or maybe there are decent exhaust shops out there that can do quality work that fits proper.bartZ32tt wrote:Moot? It would still leave you with the task of creating a one-off piece vs choosing from a selection of new or used exhausts that'll fit like a glove. I guarantee I could find a used vg30dett exhaust for cheaper than what you could make a custom rb25-z32 one for.
Okay, you got me on this one, I was basing my statement on the RB20 wiring integration which IS only about 5 wires and yes soldering... Oh noes, not teh solders.bartZ32tt wrote:Sorry, but this statement is horribly wrong. Here is a highly detailed write up on rb25-z32 wiring. Feel free to count how many wires are needed to depin and let me know. More than 5? Soldering required? You betcha.
http://forums.hybridz.org/index.php/top ... ntry438576
Thanks, I stand to inform as well from an insiders perspective. I do not know if you have bought an RB or not but your statements tend to be one sided and I just want to let people know that there are other opinions out there and other ways to do things.bartZ32tt wrote:Well, I truly hope you prove me wrong and I don't intend to discourage you; i only stand to inform. But please report back with the ending cost
totally mis-understood my comment about the engine being against the firewall (for the picture I posted). My point was that even with the engine as far back as it was in the example I gave, there was little to no room for a traditionally mounted radiator. My argument was in response to ttkickedin's remark about running the stock vg rad, but it appears that you're planning to drop $270 for a rad anyways, so this doesn't apply to your plans. However, the radiator you plan to get is 3" thick..doesn't look like you'd have enough room with the engine all the way back still...z32pilot62 wrote:The way I'm planning to do mine is with the motor as far back as physically possible, run this: http://www.summitracing.com/parts/GRI-1 ... /?rtype=10 and E-fans on the front to maximize room in front of the motor. As stated before, I plan to run a single SMIC with OE piping and that should be more than plenty for the modest power goals I have for the RB20...
Seems to be quite a bit of room back there to me and his timing cover is in about the same place as your picture. Care to elaborate on "how far back into the firewall that engine is"?
apples:oranges comparison picture; still doesn't provide proof. this is in an s-chassis and my argument was regarding the rb25; not rb20.z32pilot62 wrote:
another apples:oranges comparison. You're going off of an exhaust quote you got for a honda and applying it to a one-off FI piece. what material do you plan to use for the downpipe..aluminized steel? have fun replacing it later down the roadz32pilot62 wrote:Must be pretty expensive to get exhaust work done in your area then, downpipe back to a y-pipe before the cat back is what 4 feet? I was quoted $135 to do that on my Honda... But you are right, it probably wont fit "like a glove" or maybe there are decent exhaust shops out there that can do quality work that fits proper.![]()
Isn't that the definition of a debate - 2 or more groups representing two different sides? Nobody's arguing that there are alternative options out there. Still doesn't make them more cost effective though; especially for modest power goals, but more power to ya (no pun intended) for going against the trend and trying your own thing. That's ultimately all I'm trying to say - an rb swap into a z32 is not gonna be $3-4k.z32pilot62 wrote:Thanks, I stand to inform as well from an insiders perspective. I do not know if you have bought an RB or not but your statements tend to be one sided and I just want to let people know that there are other opinions out there and other ways to do things.
We will see when the time comes, that particular radiator is the same dimensions as a TT radiator and if all else fails then it will be put just in front of the core support and the locations of the inlet and outlet will be very easy to route for the RB(either engine). There are a couple guys using the 13" tall version of that same radiator and it is supposed to fit inside the core support so I may go that route as well, it will probably end up being the better option with the rather small RB20.bartZ32tt wrote:However, the radiator you plan to get is 3" thick..doesn't look like you'd have enough room with the engine all the way back still...
And there lies our difference of views, the 20 is actually a tad shorter than any other RB. Most people think they are exactly the same block and motor which is not true, the RB20 is basically a CA18 with 2 more cylinders.bartZ32tt wrote:apples:oranges comparison picture; still doesn't provide proof. this is in an s-chassis and my argument was regarding the rb25; not rb20.
Pwnt me again, but yes I do still think I could get a stainless piece done up quality for cheaper than you could buy quality new parts, Imo I think its unfair to try and price the swap on being able to buy used parts even though that is the most cost effective route for someone doing a VGTT swap.bartZ32tt wrote:another apples:oranges comparison. You're going off of an exhaust quote you got for a honda and applying it to a one-off FI piece. what material do you plan to use for the downpipe..aluminized steel? have fun replacing it later down the road
We will see, since I'm doing the work myself rather than buying parts that I can make myself. I will be able to drastically reduce the cost of the swap overall. I'm on track with my budget as of now and I am looking at buying anything used that I can modify to work as well as new in an effort to save myself money. Research and deal getting is key in any swap. Ill put it this way, I joined NICO due to their RB section and bought my motor about 2 months after my join date on here, been doing research and parts collecting ever since. I dont plan on spending a dime I dont have to and I want as many parts as I can get to make the swap take as little time as possible. This is not my first motor swap and wont be my last either so I do have the mind set to think out most of what im going to need to get the job done ahead of time.bartZ32tt wrote:Isn't that the definition of a debate - 2 or more groups representing two different sides? Nobody's arguing that there are alternative options out there. Still doesn't make them more cost effective though; especially for modest power goals, but more power to ya (no pun intended) for going against the trend and trying your own thing. That's ultimately all I'm trying to say - an rb swap into a z32 is not gonna be $3-4k.
