I actually experimented with this a little last night. According to the owners manual, it can only support a maximum of 512 files in a folder. I put 1000 each in 2 folders. One folder only showed 634 the other cut off at 813. I left the rest on the root folder. There were 810 listed there. That's the same total of 2257. I have no idea what's going on with it, because even after changing which files were located where, it still won't show all 2800 tracks.AppleBonker wrote:While this is not an ideal solution, it may be a valuable test:
Maybe try placing ALL of your media in one folder? I'm just wondering what the outcome would be here. I really wish I could help more, but my Bose unit didn't have the USB connection ('08) and I ripped it out withing a couple of months of owning the car. I'll try to dig up more information though.
Yeah. I've fooled with it to the point of giving up. I'll just deal. Here is what I've found though that's pretty interesting (at least to me because I'm a computer nerd). A normal mp3/media player will generally read folders/files in alphanumeric order. This means it would start with symbols, move to numbers, then on to letters, just like sorting alphabetically on your Windows Desktop does. Whoever designed this particular system, has it reading by sectors. It actually reads in the order a file/folder was written to the disk.AppleBonker wrote:Odd. So even with a 500 file limit, the unit is finding more than that? Probably a dumb question, but have you tried organizing with 500 files in each folder by like 20 folders?
And yes, I realize what a pain it is to keep tinkering with the organization on a flash drive.
The Kenwood in my old car (RIP) and the Alpine in my other ride both read Alphanumerically.AppleBonker wrote:Random other thought, but can you reverse the sorting on the flash drive? IE, have the most recently copied songs play first? And if so, would this effectively double the Bose-readable capacity of the drive?
Yeah, I think I may do the bulk flash drive thing. You can pick up 2-4GB drives for 5 or 6 bucks around the holidays. I'll just use them like CDs. I played with it a little more. Did a low level format and put them on the drive in the order I wanted to play them in. Only did about 2GB, but it appeared to play back as expected. Then I used some super fancy nerd software and rearranged their physical location on the disc. They then played in that order. I don't know, seems like a crap design to me.AppleBonker wrote:Got it. That's actually a terribly designed system. So rather then setting up playlists or something like that, you'd have to copy the files into separate directories? Time to start buying flash drives in bulk...
Edit: side note - software QA for what company if you don't mind me asking?
Luckily there is a cig adapter next to the USB port. Most external HDs have the dual end USB cord specifically for the extra power so you can just grab a 12V to USB adapter for a GPS or whatever and drop it in if need be. I'm going to give that a shot, but if it turns out the head unit can only read a limited amount of data, it's not going to matter anyway.AppleBonker wrote:Only problem with the external hard drive is keeping it powered. I don't know if the single USB port provides enough power from the head unit.
I, too, dislike Apple. But manufacturers tend to offer the best integration options for them. At least that's what I've noticed (and about the only reason I keep and iPod around).
Actually, I tried your idea. Multiple Times. It will play back in the order they were copied, but still doesn't see them all.DJBeasy wrote:No one liked my idea?![]()
Ha j/k, sounds like you have it pinned.
I did have another thought though. Is the memory device on an SD card the same as Flash memory? What if you got an SD to USB reader and tried dropping some files on the SD card? No? Ok I'll go now...
