loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Mar 19, 2010 9:15 pm
You have a lot of deferred maintenance. I hope you have at least changed the oil and filter regularly in the last 2 years of ownership. Please change the air filter (could be very dirty by now).
Your transmission problem may be due to the condition of transmission fluid, dirty/clogged transmission filter or an indication of an impending failure.
First check the level and condition of the transmission fluid (with engine warm and running). Add ATF as required. New ATF is pinkish red but your fluid is probably dirty (pale or brownish) or even burnt smell. The best thing you can do is do a pan drop, clean the pan and magnets and inspect the filter and replace as required. Use new transmission gasket during installation.
With no history of transmission service, most shops will likely refuse to do a transmission flush due to liability issue. So what you can do is multiple drain and refill. Make sure you have the correct fluid level before any drain and refill. Run the engine for @ 100 seconds while shifting gears, stop engine, then drain fluid. Add the exact amount of fluid that was drained. Repeat this process 3-4 times. At the end of the drain and refill sequence, add a bottle of LubeGard Red ATF Protectant. Make sure you don't under/over fill the transmission fluid.
For the pan drop and drain and refill, you may need @ 15 quarts of Nissan Matic-D (OEM) but Dexron III or the newer Dexron VI should do the job. You can opt for the more expensive Mobil ATF and the likes.
If shifting issues persisted, then you may have to replace the VSS (Vehicle Speed Sensor. The VSS is located close to the top of the transmission and is accessible by removing the driver side wheel and the wheel well cover.
If after doing the above yet problem remained, there could be an internal transmission problem or related controls.
