brushandcr »
https://forums.nicoclub.com/brushandcr-u142591.html
Sat Jan 11, 2014 6:59 am
Hi,
Over the last month, I get a brief (~1 second) groan/hum from driver's side when turning only after the car sits idle. Once I make 1-2 turns the problem does not return (or is noticeable) until the car sits idle again. It doesn't sound like metal on metal it is more like a low groan. I am trying to determine if its from the front or back (believe it is towards the rear but not 100% sure as of yet, plan to test at work Monday with the door or window open since it wont be as cold as last few weeks). Also, what I notice is its more apparent when sitting outside compared to testing with car garaged.
Notes:
- Nissan Maxima 2000 SE
- Nissan replaced rear brakes, pads, rotors, calipers - 5 months ago (guaranteed to 1 year or 10K miles - its in warranty but unsure if related to work they performed so wanted opinion(s) if you have them!)
- Rear tires replaced - week ago with no change to issue
Any thoughts? Thanks for reviewing.
