loekee wrote:I have a 92 GXE vg30e, when coming to a stop the idle drops, jumps up and then drops down to about 400-500rpm and shudders, then returns to around 600-700. Also when turning (while @ idle), or holding the power window switch @ the top or bottom of the track it affects the rpm by about 100 and causes the shudder as well (although no idle jump occurs). Ive replaced the distributor + cap/rotor, plugs, o2, cat and alternator, set timing to 16,set the base idle, tested the battery, alternator, had a meter on the battery and the only drop is less than 1v????
My car is doing something similar. It just surges and then dies and then repeats this for a few seconds. This has happened in highways speeds after more than an hour of driving(so the engine was warmed up). Sometimes this happens when I turn on the a/c as well. However offlate, most of the time it is happening , with /or without the a/c .
The engine also dies sometimes at traffic signals. I can immediately start it and drive.
The surging is very scary. Please help.I have changed the alternator and that did not help. Mechanic now suspects air mask, but he says, that it is only a hint. And upto me to decide. Please help guys. Is it the IAVC like it is mentioned above or something related.
HELP.
