VTRAINMAN99 »
https://forums.nicoclub.com/vtrainman99-u238714.html
Mon Jul 14, 2014 10:17 am
I have been experiencing the same issue with my 2009 Nissan Sentra. When the problems first began, I was past the original CVT warranty mileage, so I endured it on long, hilly trips. I only recently found out about the warranty extension, and I'm at 117,000+ miles, so I decided to act fast.
My local dealer has performed diagnostics, said they confirmed the high RPM and such, and is telling me that the problem is the CVT cooler, not the transmission itself. With poor cooler performance, the CVT performance is affected, which is why it seems to be o.k. after I stop for a few minutes. Replacement of the cooler, including labor and fluid, is estimated at around $1500. They also said that the cooler is not covered under the CVT warranty since the cooler is a separate unit.
So ... as with most things the dealers have practiced to say, it KINDA makes sense. But is it correct? Is it true? Is the cooler truly not covered under the CVT warranty? Would the cooler problems only result in the performance issues described in this thread on long/hilly trips? $1500 isn't insurmountable, but I don't want to spend that only for the CVT to still have trouble as I get closer to, and eventually pass, 120,000 miles!
Anyone else gotten this particular verdict before? What's the thought here ... truth or b.s.?
