Fisherdude wrote:I've done some work with my intake by puttin a k&n cold air in it and does the Mass Airflow Sensor mess up a lot?? idk if i should look into that
The MAF is a series of really thin wires, so yes it it delicate. Lots of people (in the VW) community have experienced problems with K&N filters or any oiled filters because the some of the oil will get wisked away by the intake air and stick to the MAF. Over time, this will cause the MAF to start sending incorrect readings and eventually lead to a CEL/MIL or what ever it is called.
A reuseable filter is nice and all, but you really have to watch it after you clean it and re-oil it so that you don't oversaturate it with oil. This oversaturation will lead to premature MAF failure.
Obviously a clean MAF wil get you the best performance. Also, there is special MAF cleaner on the market. You DON"T want to use carb cleaner or anything that will leave a residue.
